Since the latest firmware 1.9, are VLANS fully functional yet?
Any one made these switches work as they should?
Thanks for any info
Thanks for any info
I’am running 3 RB260 with vlans on my network ( 1.9 ) and till now i did not encounter any problem.
The management vlan also work.
Has anyone managed to mix many tagged and one untagged VLANs on the same port, is it finally possible with SwOS 1.9? It’s called Hybrid or General port mode and supported by many of the better switches (but often not by cheap or old ones, also not by Linux or ROS as far as I know - no way to specify “vlan 0” that doesn’t see tagged traffic from other VLANs on the same port); the other modes are Trunk (all tagged) or Access (one untagged) and these work in any 802.1q VLAN capable device.
I’am not using untagged/tagged vlans on the same port, my topology don’t need this, but i will test and let you know.
