VM System Specs
Can any one suggest me systme hardware specs for Virtual Machine..
i have to install winbox and pfsense firewal and raduis server in that system
Model
Processor
RAM
etc etc
each any every thing
or if any artical about it
You need to state what will be your average throughput and your peak maximum throughput.
What will the be doing ? ( PPoE , high throughput , thousands of connections , will this be router for an ISP or for home use. ) What is the desired life span of the hardware , will the load / throughput double every year ? What is the speed of your switch 1-Gig , 10-Gig , 100-Gig ? What is your budget ( cheap as possible or do it the fastest best possible way ?
