I have a weired issue and I wonder if I can have messed up my switch in anyway. CRS309-1G-8S+IN switch which I run swos 2.13 on.
My issue is that I have 2 proxmox hosts and I get line speed if I run iperf3 --bidir on the actual hosts. But If I run the same on 2 vm’s on a VLAN I get line speed one direction but half the speed in other. Running out of ideas and just wonder if you know of anyway I could have missconfigured switch? From what I remember the only thing I have done is adding VLANS to it.
Example iperf3 output host to host:
[ 5][TX-C] 0.00-10.00 sec 10.9 GBytes 9.39 Gbits/sec 144 sender
[ 5][TX-C] 0.00-10.00 sec 10.9 GBytes 9.39 Gbits/sec receiver
[ 7][RX-C] 0.00-10.00 sec 10.9 GBytes 9.37 Gbits/sec 1150 sender
[ 7][RX-C] 0.00-10.00 sec 10.9 GBytes 9.37 Gbits/sec receiver
Between VM’s on a VLAN, one vm on each proxmox host:
[ 5][TX-C] 0.00-10.00 sec 5.62 GBytes 4.83 Gbits/sec 964 sender
[ 5][TX-C] 0.00-10.00 sec 5.62 GBytes 4.83 Gbits/sec receiver
[ 7][RX-C] 0.00-10.00 sec 10.8 GBytes 9.31 Gbits/sec 25699 sender
[ 7][RX-C] 0.00-10.00 sec 10.8 GBytes 9.30 Gbits/sec receiver
May not be related to switch at all but I have just run out of ideas. Would be more logical if speed was bad both ways.
