I want to see and analyze the traffic of the virtual server installed on vmware with mikrotik.I guess mikrotik needs to work in bridge mode for this.But no matter how hard I tried I failed.I want see traffic and prevent specific attacks.
First, you need to enable promiscuous mode on the vswitch port groups your routerOS vm is connected to. Since that impacts all other vms as well, I-d advise to create another port group just for this vm on the vSwitch (the one that has physical adapters and has the “VM Network” port group on it)
Second, if I am not totally wrong, you should check “use IP Firewall” in bridge settings in your routerOS vm.
Thanks, It worked when I did it the way you said. → http://prntscr.com/ue9lec
But now i am seeing the traffic of all virtual servers on mikrotik, do i need to connect a second ethernet cable to the server for promiscuous mode?
