Hello !
I have the following Configuration:
VMware ESXi v6.0.0
Virtual Machine Properties:
CHR-6.42.3
RAM: 16Gb
CPU: 8
Disk1: [SSD-460Gb] THE.DUDE - xxx.xxx.xxx.xxx/chr-6.42.3.vmdk
Virtual Device Node: IDE
Disk2: [SSD-460Gb] THE.DUDE - xxx.xxx.xxx.xxx/THE.DUDE - xxx.xxx.xxx.xxx.vmdk
Virtual Device Node: SCSI
I try to upgrade packages from 6.42.3 to 6.42.4 and then router os try to download package i get error on VMware
Virtual Machine Message
The operation on the file “/vmfs/devices/deltadisk/4e575c2a-chr-6.42.3-s001.vmdk” failed(14 (Bad address)).
The file system where disk “/vmfs/devices/deltadisk/4e575c2a-chr-6.42.3-s001.vmdk” resides is full.
Select button.retry to attempt the operation again.
Select button.abort to end the session.
On the SSD where is CHR installed is more that 200 Gb free unused space.
Then i run CHR virtual machine from VMware its start for 2-8 seconds and after goes down with this error.
To reinstall completly chr on new version don\t solve the problem. on next update will be the same.
Please help up to resovle the problem !
