Hi Guys,
This is my following setup:
Each Vmware server has two network adapters teamed going to the Juniper switch.
There are two ports on the Juniper switch going to the CCR on ether11 and ether12. These interfaces are bonded using 802.3ad. I have a bridge with all vlans attached to it, which is attached to the bonded interface.
It’s not working.
What am I doing wrong here?
What I am trying to do is pass all vlans to my vmware servers. They are set at the moment to listen for any vlan. Should I be doing this differently?
bridge
add l2mtu=1590 name=bri-trunk
bridge ports
add bridge=bri-trunk interface=bonding1
vlan
add interface=bri-trunk l2mtu=1586 name=test vlan-id=1020
bonding
add mii-interval=1s mode=802.3ad name=bonding1 slaves=ether11,ether12 \
transmit-hash-policy=layer-2-and-3
address
add address=10.200.20.1/24 interface=bonding1 network=10.200.20.0
Here is the Juniper Config for the trunk from the router to switch
ge-0/0/46 {
description CORE_RTR_PORT_1_AE1;
ether-options {
802.3ad ae1;
ge-0/0/47 {
description CORE_RTR_PORT_2_AE1;
ether-options {
802.3ad ae1;
ae1 {
description CORE_RTR_AE1;
aggregated-ether-options {
no-flow-control;
minimum-links 1;
lacp {
active;
periodic fast;
unit 0 {
family ethernet-switching {
port-mode trunk;
vlan {
members all;
And finally vlans defined on the switch
vlans {
vlan100 {
description Internal;
vlan-id 100;
vlan1002 {
description 1002;
vlan-id 1002;
vlan1003 {
description 1003;
vlan-id 1003;
vlan1020 {
description TEST_1020;
vlan-id 1020;
vlan5 {
description Management;
vlan-id 5;
vlan9 {
description Temp_MGMT;
vlan-id 9;
l3-interface vlan.9;
