VMWare Support Please
It seems that there are a number of people who want to run MT in VMWare. And, it also seems that it is not clearly understood as to why.
Some feel that it would be great to just put it in a container on your workstation and use it as a firewall. But, we have much bigger plans.
We are a Telco Carrier and ISP. We have thousands of PPPoe connections we support and maintain. We want to switch to MT. But, MT is not exactly a carrier class product . . . Don’t get me wrong. It is a fabulous product. But, we need redundancy. We need fast routers which can handle lots of RAM . . . and lots of connections. MT does a great job. But, we need to have a means to automatically recover from failures quickly . . . and scale the connection capacity without bound.
Our solution is to run MT on VMWare. We give MT as much RAM as it will take, and all the disk it wants. We have settled for the default network drivers. And, it all works. And, we can run three or four MT instances on one machine. But, we are still missing vmware-tools and most importantly the vmxnet interface.
With the tools, we would be able to restart containers if and when there is a problem. As well, we can start and stop containers when connection loads exceed the capacity of one, two, or three MT instances. That many MT instances can handle a bunch of PPPoe connections.
So, if anyone would be interested in including vmware-tools and vmxnet as an addition to MT, we would appreciate it greatly. If not, we will keep doing what we are doing. But, it would be easier if we had the interface and tools.
Take care and thanks for the great product. Keep up the good work.
Tell VMWare that it’s a 64 bit guest and you will get a better NIC (intel pro 1000 actually)
We have been testing vmware RouterOS and it seems to work 90% of the time, however under any type of small load it starts to drop packets. I haven’t dug back into it to see why exactly, i think it had to do with some vlans on the host or something.
Sam
