Vodafone 3G K3570-Z USB Modem
Hi
Does anyone know if its possible to get the Vodafone K3570-z 3G modem working with the 411auh? Its the only modem I could get in this part of Rural norfolk at short notice, and I need to have a working solution for Monday. It does not show up when printing the USB config so I assume its not recognised but im sure it cant be that much different to any other USB 3g dongle.
Help!
Make sure you have tried the following,
Good day,
Has anybody resolved this issue?
I am also not able to connect with this device.
I connected the K3570-Z device with version 5.2 on RB951H-2HnD - Not working…
I upgraded RB to ver 6.2 - Not working.. when connecting the device, the System resources shows the device in USB, but when adding the PPP client the port shows unknown.
I connected USB 3G Device K3772 and the PPP connection was automatically created. While this was online, I downloaded and upgraded the RB to Ver 6.4
Disabled PPP connection created automatically and removed K3772 modem.
Added K3570-Z to the RB and was able to selct usb1 when creating new PPP connection. Was not able to establish a connection however, as data port was not found. When checking the data port used was 0 and info port was 0 (Default) Perhaps this needs to be changed…
I cannot use K3772 as this is a loan device, and I need to use the device that I own which is the K3570-Z
Please advise
“This is how you spell colour”
