I have set up the following constellation:
ISP ---------------- Bridge Master - - - - Bridge Slave ---------------- Switch --------------- Access Point
Vodafone Station wAPG-60ad wAPG-60ad Zyxel GS1200-5HP cAP ac
(192.168.0.1) (192.168.88.3) (192.168.88.2) (192.168.88.1)
The switch is mainly used as PoE power supply for bridge slave and AP.
At the beginning, I set up a short test “in the kitchen” - the same constellation but with the old ISP (DSL / FritzBox) - no configuration on the (preconfigured) MikroTic devices at all - That worked! I had internet on the cAP.
Then I installed the wAPGs at the place they are intended for (outside, 20m distance, sight contact) and attached the new ISP. Result: No Internet at the AP and no Traffic over the bridge. On slave side it looks not bad - I can reach the AP and bridge slave via IP address with WINBOX (PC plugged into the switch). But I see no traffic on the bridge. On Master side it’s confusing: I cant’ reach the bridge master with WINBOX via IP (PC plugged into Vodafone Station) only via MAC address. When I logged in via MAC address the first time, the RouterOS looked like a simple AP - no bridge. After a reboot that changed to the look of the slave, and I thought, that was the problem - but I have still no Internet. No traffic shown on the 60GHz route …
What’s wrong? Would be nice, if somebody has an idea …
LG,
Chris
