Hi, has anyone managed to get a Vodafone Sure Signal 3G booster connected and working behind a RouterOS device, it is supposed to make an IPSEC connection to the Vodafone network over the internet but nothing I do appears to allow it to work. Any help will be gratefully received.
Hey dominicbatty
becomes the 3g modem as a LTE interface?
forget it, turns out the Vodafone sure signal only works if you can get 1500 byte MTU out to the internet.
Ugh,
Does that mean its not fixable to work with Mikrotik??
Every Mikrotik can do 1500 byte MTU. Does your ISP use PPPoE or any other ‘low MTU’ protocol?
It depends on your firewall rules - use the wiki for IPSEC tunnels to find what type of traffic is used, and create rules that allow that kind of traffic to be forwarded to the local network or device. It should work under normal firewall rules, but who is to say what is normal, eh?
Have a fiddle around, and please drop some feedback after. It may help someone else
I just thought - enable uPNP and make sure the interfaces are set correctly for it, before messing with the firewall. It may ‘fix itself’.
Tony
I am not really sure if this answeres your question but i used this booster http://www.wilsonamplifiers.com/mobilewireless-amplifier-only-50db-3g-wireless-801201/ with a RouterOS device.
worker really great!
Answer is simple.
Visit https://www.myamplifiers.com/catalog/3g.
Boosters in this store are cheaper then in wilson. And it works good. I recommend
