Voice Vlan's and outside DHCP
I just install a new high speed Mikrotik for a client. I have them at home but now I guess I actually have to do stuff with it and I’m lost.
I need three things
  1. “regular” data traffic on it’s own vlan (192.168.50.0/24) Voice traffic on another vlan (192.168.51.0/24)
  2. Each vlan has it’s own DHCP server
  3. The Computers AND Cisco SPA504g’s are both receiving outside DHCP, so it would be nice to block DHCP and have them go to the mikrotik for DHCP
Basically, my ether1 port needs to not allow dhcp to pass or send dhcp out…
Any help would be greatly appreciated!
Rather than tell you what I’ve tried here’s my /export
# software id = GJ48-LCK8
add admin-mac=00:0C:42:F8:B2:D4 auto-mac=no l2mtu=1598 name=bridge-local \
    protocol-mode=rstp
/interface wireless
set 0 band=2ghz-b/g/n channel-width=20/40mhz-ht-above disabled=no distance=\
    indoors ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 mode=ap-bridge ssid=\
    "Power Gen Wifi" wireless-protocol=802.11
set 0 name=ether1-gateway
set 5 name=ether6-master-local
set 6 master-port=ether6-master-local name=ether7-slave-local
set 7 master-port=ether6-master-local name=ether8-slave-local
set 8 master-port=ether6-master-local name=ether9-slave-local
set 9 master-port=ether6-master-local name=ether10-slave-local
set 10 name=sfp1-gateway
/ip neighbor discovery
set ether1-gateway discover=no
set sfp1-gateway discover=no
/interface vlan
add interface=bridge-local l2mtu=1594 name=Data use-service-tag=yes vlan-id=1
add interface=bridge-local l2mtu=1594 name=Voice use-service-tag=yes vlan-id=\
    100
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=america12 \
    wpa2-pre-shared-key=america12
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
    mac-cookie-timeout=3d
add name=dhcp_pool1 ranges=192.168.50.100-192.168.50.254
add name=dhcp_pool2 ranges=192.168.51.100-192.168.51.254
add address-pool=default-dhcp interface=bridge-local name=default
add address-pool=dhcp_pool1 disabled=no interface=Data name=Data
add address-pool=dhcp_pool2 disabled=no interface=Voice name=Voice
/port
set 0 name=serial0
add bridge=bridge-local interface=ether2
add bridge=bridge-local interface=ether3
add bridge=bridge-local interface=ether4
add bridge=bridge-local interface=ether5
add bridge=bridge-local interface=ether6-master-local
add bridge=bridge-local interface=wlan1
add address=192.168.88.1/24 comment="default configuration" interface=wlan1 \
    network=192.168.88.0
add address=192.168.50.1/24 interface=Data network=192.168.50.0
add address=192.168.51.1/24 interface=Voice network=192.168.51.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no \
    interface=sfp1-gateway
    interface=ether1-gateway
add address=192.168.50.0/24 dns-server=192.168.50.15,192.168.50.1 gateway=\
    192.168.50.1
add address=192.168.51.0/24 dns-server=192.168.50.15,192.168.50.1 gateway=\
    192.168.51.1
add address=192.168.88.0/24 comment="default configuration" dns-server=\
    192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=\
    sfp1-gateway
    ether1-gateway
add chain=forward comment="default configuration" connection-state=established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" connection-state=\
    invalid
add action=masquerade chain=srcnat comment="default configuration" \
    out-interface=sfp1-gateway
    out-interface=ether1-gateway to-addresses=0.0.0.0
/lcd interface
set sfp1-gateway interface=sfp1-gateway
set ether1-gateway interface=ether1-gateway
set ether2 interface=ether2
set ether3 interface=ether3
set ether4 interface=ether4
set ether5 interface=ether5
set ether6-master-local interface=ether6-master-local
set ether7-slave-local interface=ether7-slave-local
set ether8-slave-local interface=ether8-slave-local
set ether9-slave-local interface=ether9-slave-local
set ether10-slave-local interface=ether10-slave-local
set wlan1 interface=wlan1
/lcd interface pages
set 0 interfaces="sfp1-gateway,ether1-gateway,ether2,ether3,ether4,ether5,ether6\
    -master-local,ether7-slave-local,ether8-slave-local,ether9-slave-local,ether\
    10-slave-local"
/system identity
set name=PGC-Core
/tool mac-server
add interface=ether2
add interface=ether3
add interface=ether4
add interface=ether5
add interface=ether6-master-local
add interface=ether7-slave-local
add interface=ether8-slave-local
add interface=ether9-slave-local
add interface=wlan1
/tool mac-server mac-winbox
add interface=wlan1
Since you have bridged all your interfaces and configured the default DHCP server to the local bridge, the clients connected to the ether/wlan interfaces will receive an IP from that default (192.168.88.0/24) dhcp pool.
Is your equipment VLAN aware?
I suggest you just get rid of the default 192.168.88.0/24 config items and leave the desired DHCP settings exist.
I have tried to do the same but did not get it running.
Since the DHCP servers are attached to the VLAN interfaces and the systems connected to the ether interfaces are not VLAN aware, this is not going to work.
I have to check the possibilities and will come back to it as soon as possible.
