VOIP AND WIRELESS
Hi everybody,
does anyone know if there are some configurations to be applied to cpe (for example Mikrotik SXT) to make the best voip?
Thanks!
if there is a link, voip will work. if you have some specific requirements, or have some specific issues - let us know in detail. there is no generic “best voip” setup. are you looking for low latency or something else? clarify please.
I believe you need some queuing setup that gives voip priority over other user traffic. VoIP does not need much traffic, but latency is critical. I would also like to hear some opinions about how to implement any means to shape traffic at client side and at AP’s in p2mp scenarios aswell.
Hello all.
I also need some advice on VoIP, we have got 2 PPTP’s running, one for the VoIP service and one for the internet service. Is there any way that I can put one set of QoS on both PPTP’s?
Wireless link stats
Signal strenth -72/-73
Quality between 85 and 98
P Throughput 5535kbps
