Two years ago I got connected to FTTH. Since then I use a Mikrotik CCR2004-1G-12S+2XS main router and -not the problem- a CRS305 and a CSS610 switch. My ISP offers a SIP telephone service, but only with IPv6 connection. OK, I know there is a IPv4 test connection although, but just with a extreme low capacity that does not even work by night. For telephone I use a Fritz-box, which is direct locally connected to the main router via a SFP to RJ45 (S-RJ01) converter module. This Fritz-box is configured not to work as a router, do no switch or WLAN or else, but be just a IPv6 DECT telephone base with LAN connection only. Still IPv6 DECT bases are rare. This has been tricky to configure, but it worked well for two years with several updates.
A few days ago I made an update for the CCR2004 router. It has still been running ROS 7.11 and then got updated to 7.14.1, and just now to 7.14.2. But since that first update, my SIP phone does not work anymore. In the past I used all UDP connection for SIP port 5060, but now I can not register my accounts with UDP. How ever, this works with TCP for the port 5060 SIP traffic. But now I have upstream UDP RTP contact only. That means, I can call someone, where the phone rings and my voice is present, but the downstream packets back do not pass through to my Fritz-box DECT base. And I can not be called. Of cause I have tried and changed a lot to solve this. But I did not manage that. It is special that AVM Fritz-boxes use 32 UDP ports 7078-7109 for RTP. 7078 or 7080 are used first. That eases filtering.
In a phone call, downstream incoming SIP & RTP UDP packets enter WAN, are counted and accepted in prerouting, and are accepted in forward chain, but they do not arrive at destination LAN port if they are UDP protocol. At port 5060 I have captured both TCP and UDP up- and downstream traffic. TCP works, but the UDP downstream does not arrive at LAN port, same as with RTP. The interface of the packets is not developed pppoe-out1 → bridge1 → sfp-sfpplus9 like with TCP, but just pppoe-out1 → pppoe-out1 with UDP downstream. Captured with packet sniffer with IP protocol: udp & tcp, port: 7078 & 7080 & 5060 (->sip) filter.
UDP or TCP up:
Interface sfp-sfpplus9 . rx . Src. bridge1:sfp9mac . Dst. ISP-SIP_adr::20 . port: 7078->31632
Interface bridge1 … . rx . Src. bridge1:sfp9mac . Dst. ISP-SIP_adr::20 . port: 7078->31632
Interface pppoe-out1 .. tx . Src. pppoe-out1:mac . Dst. ISP-SIP_adr::20 . port: 7078->31632
UDP down ~ 12 (9-16)ms later:
Interface pppoe-out1 . rx . . Src. ISP-SIP_adr::20 . Dst. pppoe-out1:mac . port: 31632->7078
Interface pppoe-out1 . tx . . Src. ISP-SIP_adr::20 . Dst. bridge1:sfp9mac . port: 31632->7078
next up about 12ms later. TCP down looks reverse ordered like TCP/UDP up.
Actually in my raw ipv6 prerouting chain there are two filters to accept anything from source of a sip_server_ipv6 address list and separated same to destination of this address list. My ISP offers three /64 SIP server addresses, which are on that list, but just one address got used, no proxy. Address switches from A:B:C::8 for SIP to A:B:C::20 for RTP or else. In mangle there are four filters to mark packets with port [5060-5062,7078-7109], one for TCP and one for UDP with Dst. address list sip_server_ipv6 marking packets VOIP_to_WAN and same with Src. address list marking packets VOIP_to_LAN. I have tried filters with connection state “new”. They match for a 1/2 percent of upstream packets, but not at all for downstream UDP packets, not even in prerouting chain. So connection marking will not work, and I mark every single packet. One rule for TCP and UDP is not possible, but they get same marking. I got same count results for mangle rules with rerouting or forward or post routing chain. I use forward chain for UDP downstream marking VOIP_to_LAN and additional passthrough filters in rerouting and in post routing chain count the same packet number. In the IPv6 filter rules there are two separated passthrough rules to count the packages matching either VOIP_to_LAN or VOIP_to_WAN marking. The packet count is almost perfect same for up and down and same to the raw rerouting chain. Packets are then last time together counted and forward accepted by a “defconf: established, related, untracked” rule, just with that connection states. Some rules like “accept IKE” are disabled, so there are no more different rules for TCP and UDP at all.
If the router is disconnected except for the Fritz-box, one PC and of cause pppoe WAN, a “defconf: enable for transparent firewall” top rule is enabled (just accept in raw rerouting chain) and in the filter rules the “established, related, untracked” rule is pulled to of the list: That does not help. In Webfig Interfaces->bridge1 and ->sfp-sfpplus9 allow to show the highly asymmetric traffic during a phone call.
I do not know anything about SIP ALG with IPv6. Seems it does not matter, if IPv4 sip service port and Direct Media are enabled or not. Are packets lost in postroute or even in the linux kernel of the router? Why is no new connection state labelled? The issue that there is no SIP downstream is quite common, but all cases I have found are based on IPv4 or related to multiple external addresses.
