VOIP over VPN Issues
Hi guys,
I’m having some difficulty with the following setup:
Main Site :
1 x a2billing server which is the main voip gateway in and outbound. (10.11.200.2)
1 x Mikrotik RB750 (10.11.27.200)
VPN Site :
1 x asterisk server connecting over PPTP to the Main Site’s Mikrotik directly. (10.11.202.115 as a VPN IP at the Main Site)
Basically what i’m doing is when a call is incoming from the Main Site’s gateway, it gets routed to 10.11.27.200 and from there the Mikrotik translates it to 10.11.202.115. (This happened by itself, i didn’t add any rules).
On both PBX’s I can see the call going through however it gets drop because of some port issue. It can open the data channel but not the voice channel.
I am thinking perhaps I need to add something to the Mikrotik in NAT to point that 10.11.27.200 on ports 5060 & 10000-20000 should be forwarded to 10.11.202.115, but for the life of me I can’t wrap my head around this (or implement it for that matter with my tiny brain).
The crux is that from the VPN Site i can easily ping 10.11.200.2 but from the Main Site obviously when pinging 10.11.27.200 it pings the mikrotik and not the VPN Site’s box…
Also, no matter what type of registration I do on the SIP trunks the Main Site always sees the VPN Site’s IP as 10.11.27.200.
Any suggestions from any brainy people out there?
Thank you
Will
It is much easier to use IAX connections between the Asterisk boxes because all Control and Audio are sent over the same port/connection.
Do you have MT on both sides of the VPN or are you using VPN Client on the Remote PBX to connect to the RB750? If yes, I have never done that but I have setup multiple sites, each behind RB493AH with a MT<–>MT PPTP connection and this works flawlessly.
Can you detail the network configuration a bit more and post your IP->Route tables and IP->Firewall->NAT rules and IP->Firewall->Filter rules for further investigation.
