Voip Prioritize (Again)
It seems a lot of users are struggling prioritizing Voip traffic.
I searched the internet and tried some scripts and samples.
I’m not a mikrotik expert and could not get right.
I could not found any working script.
Can somebody help me?
I have a simple setup:
WAN Interface
Lan Interface
Sip server = 196.1.1.1 (Example)
Lan IP range 192.168.0.0
Voip Equipment IP 192.168.0.27
No for the gig question
How do I prioritize my Voip traffic?
It seems I must first mark the packets and then use a queue to prioritize it.
Thank You
Check out this post. I have only one part, (the TOS) I haven’t figured out yet.
http://wiki.mikrotik.com/wiki/Voip
The most effective solutions include using dedicated VoIP switches and routers as well as traffic shaping based on TOS (type of service). This type of solution implies buying proper hardware and consulting the product manual.
Well I think that it is not a big issue that you are having and for this you must need to get contact with the VoIp operation expert as he can just make you the best deals and you can get the nice suggestions all about.
There are the nit tie-gritties that you can only do with a manual. online resources are in plenty and you can check them out
