Basically I’m running MT3.0b8 due to its better support of Sata drives compared to 2.9. Everything went smoothly up until one of my customers call in to complain about his VoIP phone no longer worked correctly. You can pickup the phone and dial out correctly, and it functions well, but when you try to call into the phone it rings and then doesn’t transfer any voice data after that.
It worked fine in 2.9, but now doesn’t.
Here is what I know, the phone use 5060-5061 UDP and 10000-20000 UDP, and is using the sip protocol, its a Polycom phone using Aptela. I know that I didn’t change much in the routers configuration between 2.9 to 3.0, but from what I read how MT3.0b8 handles sip is quite different then 2.9.
Anyone know what I’m doing wrong? Or rather what I can do to fix this?
my issue was about sip helper. in face using it the rtp stream went from the clients to sip proxy and not between customers. So the call was setted up fine but no audio on the phone.
you can log the rtp to see if you have the same issue.
