Voip Problem
I’m using a ccr1016 as a PPPoE server with Splynx and an RB311UiAS to make a 4 wan load balance in PCC, if I use both addresses as a mark connection, the load balance works perfectly but all VoIP connections do not last longer than 4 minutes and disconnect, if instead of imposing on src addresses the load balance does not work while voip calls work regularly.
Does anyone have a solution?
Otherwise I was thinking of hijacking all voip traffic coming to ccr1016 via PPPoE connections to a specific connection outside of the PCC Load Balance.
Can someone help me? thank you so much
