VOIP QOS Problems
Hey guys,
I’m hoping that someone can help me troubleshoot some VOIP QOS that I’ve been trying to do. I have a 24mb/3mb connection. The bridge is called “LAN PORTS”.
-I created the Mangle rules to mark the packets: https://puu.sh/tl371/43a0a228e3.png
-I created the Queue to give the bridge 15/1: https://puu.sh/tl3ap/8454c9a25e.png
-I created the Queue to give the marked VOIP packets unlimited: https://puu.sh/tl3ct/fee3421f2c.png
-However I’m not seeing any traffic pass through the VOIP queue, so it looks like the QOS is not working although the packets are being marked: https://puu.sh/tl3eu/32facb9085.png
Any suggestions here? Thanks!
Please post your config as export instead of screenshots.
How is that done?
Open a new terminal window and type /export
Copy and paste the relevant sections (ip firewall and queue, at least) here.
jan/13/2017 11:51:35 by RouterOS 6.38
add admin-mac=6C:3B:6B:48:AF:DB auto-mac=no comment=defconf name="LAN PORTS"
set [ find default-name=ether1 ] name=INTERNET
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
add bridge="LAN PORTS" comment=defconf interface=ether2-master
add bridge="LAN PORTS" comment=defconf interface=wlan1
add bridge="LAN PORTS" interface=wlan2
add action=accept chain=input dst-port=8291 protocol=tcp
add action=accept chain=input dst-port=80 protocol=tcp
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
add action=accept chain=input comment="defconf: accept establieshed,related"
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
add action=drop chain=input comment="defconf: drop all from WAN" in-interface=
INTERNET
add action=accept chain=forward comment="defconf: accept established,related"
add action=drop chain=forward comment="defconf: drop invalid" connection-state=
invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
connection-state=new in-interface=INTERNET
/ip firewall mangle
add action=mark-packet chain=forward connection-state="" log=yes log-prefix=
VOIP new-packet-mark=VOIP passthrough=yes protocol=tcp src-port=5060
add action=mark-packet chain=forward connection-state="" dst-port=5060 log=yes
log-prefix=VOIP new-packet-mark=VOIP passthrough=yes protocol=tcp
VOIP new-packet-mark=VOIP passthrough=yes protocol=udp src-port=5060
log-prefix=VOIP new-packet-mark=VOIP passthrough=yes protocol=udp
add action=mark-packet chain=forward log=yes log-prefix=VOIP new-packet-mark=
VOIP passthrough=yes protocol=tcp src-port=10000-20000
VOIP passthrough=yes protocol=udp src-port=10000-20000
add action=mark-packet chain=forward dst-port=10000-20000 log=yes log-prefix=
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=
INTERNET
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=
192.168.89.0/24
/ip firewall service-port
set sip disabled=yes
/ip service
set www address=0.0.0.0/0
set winbox address=0.0.0.0/0
/ip upnp
set allow-disable-external-interface=yes enabled=yes
I don’t see an immediate error, maybe others do. I am not used to doing it this way, I normally mark using
the DSCP value that specifies the priority of the traffic:
/ip firewall mangle
add action=set-priority chain=postrouting comment="From dscp high 3 bits" \
    new-priority=from-dscp-high-3-bits passthrough=yes
add action=mark-packet chain=postrouting comment="Priority 0" \
    new-packet-mark=prio0 passthrough=yes priority=0
add action=mark-packet chain=postrouting comment="Priority 1" \
    new-packet-mark=prio1 passthrough=yes priority=1
add action=mark-packet chain=postrouting comment="Priority 2" \
    new-packet-mark=prio2 passthrough=yes priority=2
add action=mark-packet chain=postrouting comment="Priority 3" \
    new-packet-mark=prio3 passthrough=yes priority=3
add action=mark-packet chain=postrouting comment="Priority 4" \
    new-packet-mark=prio4 passthrough=yes priority=4
add action=mark-packet chain=postrouting comment="Priority 5" \
    new-packet-mark=prio5 passthrough=yes priority=5
add action=mark-packet chain=postrouting comment="Priority 6" \
    new-packet-mark=prio6 passthrough=yes priority=6
add action=mark-packet chain=postrouting comment="Priority 7" \
    new-packet-mark=prio7 passthrough=yes priority=7
Then I use a Queue Tree to queue the traffic with priority classes:
/queue tree
add comment="20 Mbps" limit-at=19M max-limit=19M name=\
    queue-vlan51 parent=ether1.vlan51 queue=default
add limit-at=4M max-limit=18M name=queue-vlan51-p1 packet-mark=prio7 parent=\
    queue-vlan51 priority=1 queue=default
add limit-at=4M max-limit=18M name=queue-vlan51-p2 packet-mark=prio6 parent=\
    queue-vlan51 priority=2 queue=default
add limit-at=4M max-limit=18M name=queue-vlan51-p3 packet-mark=prio5 parent=\
    queue-vlan51 priority=3 queue=default
add limit-at=4M max-limit=18M name=queue-vlan51-p4 packet-mark=prio4 parent=\
    queue-vlan51 priority=4 queue=default
add limit-at=4M max-limit=18M name=queue-vlan51-p5 packet-mark=prio3 parent=\
    queue-vlan51 priority=5 queue=default
add limit-at=4M max-limit=18M name=queue-vlan51-p6 packet-mark=prio2 parent=\
    queue-vlan51 priority=6 queue=default
add limit-at=4M max-limit=18M name=queue-vlan51-p7 packet-mark=prio0 parent=\
    queue-vlan51 priority=7 queue=default
add limit-at=4M max-limit=18M name=queue-vlan51-p8 packet-mark=prio1 parent=\
    queue-vlan51 queue=default
When the traffic is properly marked by the endpoints (with VoIP it often is), there is no need to use
marking by port numbers etc.
I guess that this is the only solution that I can try. I have added the mangle rules, but on the queue, the connection is 18M down and 1.5M up. From your script, it seems like 20/20 down/up. How can this be made asynchronous? Thanks!
The values you use in the queue tree are solely based on your upload speed.
The shaping for the download has to be done by the ISP.
Just to verify, is this the correct syntax?
/queue tree
add comment="1.5 Mbps" limit-at=1M max-limit=1M name=\
add limit-at=1M max-limit=1M name=queue-vlan51-p1 packet-mark=prio7 parent=\
add limit-at=1M max-limit=1M name=queue-vlan51-p2 packet-mark=prio6 parent=\
add limit-at=1M max-limit=1M name=queue-vlan51-p3 packet-mark=prio5 parent=\
add limit-at=1M max-limit=1M name=queue-vlan51-p4 packet-mark=prio4 parent=\
add limit-at=1M max-limit=1M name=queue-vlan51-p5 packet-mark=prio3 parent=\
add limit-at=1M max-limit=1M name=queue-vlan51-p6 packet-mark=prio2 parent=\
add limit-at=1M max-limit=1M name=queue-vlan51-p7 packet-mark=prio0 parent=\
add limit-at=1M max-limit=1M name=queue-vlan51-p8 packet-mark=prio1 parent=\
I tried that and got this result:
[admin@CN-Router] /queue tree> add limit-at=1M max-limit=1M name=queue-vlan5
\...     queue-vlan51 priority=4 queue=default
input does not match any value of parent
\...     queue-vlan51 priority=5 queue=default
\...     queue-vlan51 priority=6 queue=default
\...     queue-vlan51 priority=7 queue=default
\...     queue-vlan51 queue=default
You should of course adapt the example to your local situation, e.g. in this case the interface name and queue name.
Here is what I came up with to try to simplify/understand:
/ip firewall mangle
    new-packet-mark=OTHER passthrough=yes priority=0
    new-packet-mark=OTHER passthrough=yes priority=1
    new-packet-mark=OTHER passthrough=yes priority=2
    new-packet-mark=VOIP passthrough=yes priority=3
    new-packet-mark=VOIP passthrough=yes priority=4
    new-packet-mark=VOIP passthrough=yes priority=5
    new-packet-mark=VOIP passthrough=yes priority=6
    new-packet-mark=VOIP passthrough=yes priority=7
/queue tree
add name="LEVEL_A_UP"   parent=INTERNET queue=default max-limit=900k
add name="LEVEL_A_DOWN" parent=LAN-PORTS queue=default max-limit=15M
add name="LEVEL_B_UP"   parent=INTERNET queue=default max-limit=900k
add name="LEVEL_B_DOWN" parent=LAN-PORTS queue=default max-limit=15M
add name="VOIP_U"       parent="LEVEL_A_UP"   packet-mark="VOIP"  queue=default priority=1
add name="VOIP_D"       parent="LEVEL_A_DOWN" packet-mark="VOIP"  queue=default priority=1
add name="OTHER_U"      parent="LEVEL_B_UP"   packet-mark="OTHER" queue=default priority=2
add name="OTHER_D"      parent="LEVEL_B_DOWN" packet-mark="OTHER" queue=default priority=2
