nemecio
November 15, 2007, 6:48am
1
Hello all,
I need some help, i saw in a post that this is the right way to prioritize voip trafic for bandwidth hog vonage…
I did copy this from someone else but do not seem to work… i still get broken voice when trying my calls…
Any help would be appreciated…
Those are my firewall mangle rules…
0 chain=prerouting dst-port=10000-20000 protocol=udp
connection-mark=VoIPConn action=mark-connection
new-connection-mark=VoIPConn passthrough=yes
1 chain=prerouting connection-mark=VoIPConn action=mark-packet
new-packet-mark=VoiPAck passthrough=no
2 chain=postrouting dst-port=10000-20000 protocol=udp
3 chain=postrouting connection-mark=VoIPConn action=mark-packet
4 chain=forward p2p=all-p2p limit=1,5 action=mark-connection
new-connection-mark=p2p_conn passthrough=yes
5 chain=forward connection-mark=p2p_conn limit=1,5 action=mark-packet
new-packet-mark=p2p passthrough=yes
And these are my queue tree rules:
0 name=“VoIP” parent=global-total packet-mark=VoiPAck limit-at=128000
queue=default priority=1 max-limit=128000 burst-limit=0
burst-threshold=0 burst-time=0s
1 name=“P2P_in” parent=global-in packet-mark=p2p limit-at=3000 queue=default
priority=8 max-limit=64000 burst-limit=0 burst-threshold=0 burst-time=0s
2 name=“P2P_out” parent=global-out packet-mark=p2p limit-at=3000
queue=default priority=8 max-limit=32000 burst-limit=0 burst-threshold=0
burst-time=0s
The p2p rule seems to work since i do get some readings out of it.
But VOIp i get nothing…
Please help…
Saludos From mexico
tgrand
November 15, 2007, 12:39pm
2
This rule is only going to mark VoIPConn only if it is already marked VoIPConn.
Try this:
However ports 10000-20000 could also be used for p2p, so move the rule below the packet marking for p2p.
nemecio
November 15, 2007, 3:58pm
3
I have read the “move rule” “place rule first” so on and so forth but dont know how to “move” them around…
It must be something really stupid but i have not been able to figure out how to “move” rules around.
The only way i figured out to “move” the rule was to disable rule 0 and place a new rule at the end of the list…
Thank you for the swift reply…
Now it looks like this already modified:
0 X chain=prerouting dst-port=10000-20000 protocol=udp action=mark-connection
6 chain=prerouting dst-port=10000-20000 protocol=udp action=mark-connection
GWISA
November 19, 2007, 2:14pm
4
I would identify the VoIP traffic by server IP if possible…
And to move rule, simply drag it to where you want it to be in winbox…
nowires
November 19, 2007, 3:46pm
5
In my opinion it’s the best way.
nemecio
November 19, 2007, 5:09pm
6
I told you it would be something easy… (it’s the kind of stuff newbies want to learn but is documented nowhere)
Thank you, now I can “move” the rules all over the place as needed…
Have a great day…
