I need to start using some QoS for VoIP calls.
However it seems firewall mangle only accepts TOS values between 0 and 63 but I have Linksys devices that have default TOS=0x68 (decimal 104) and TOS=0xb8 (dec 184) and my Asterisk boxes use 0xef (dec 239) as default to name but a few. What gives?
I really do not want to reconfigure all my client devices to implement QoS based on TOS values.
I don’t see how that can be, unless I’m really missing something here.
DSCP uses the lower 6 bits of the ToS byte, which means values between 0 and 63. The last two bits are for ECN (explicit congestion notification) and shouldn’t be used for anything else.
It depends on whether or not the software looks at the value as an 8 byte value (the entire TOS byte), or just the six bits used for DSCP. To convert between the two you multiply by four (to go from 2^6 to 2^8). RouterOS looks at things as a 6 byte field, whatever Linksys equipment you have as well as the Asterisk server look at it as an 8 byte field.
Seems to be working for 0xb8 (dec/8= 46) but not for 0xef (dec/8=59) but then again, 184(0xb8) is divisible by 4 but 239(0xef) not, don’t know if that’s an issue.
Ekkas
