voltage on RB260GSP
i wish to buy mikrotik switch https://routerboard.com/RB260GSP but i wonder does this switch has voltage oid? does it have voltage on the system menu?
could anyone help me to check please?
much appreciated.
System tab shows input voltage and temperature. Port tab shows current usage per-port.
I don’t know if this is available over SNMP - if it is, LibreNMS (which I use) doesn’t have support for the relevant OIDs.
Hi Aholmes,
thanks for your help, im glad to hear that has voltage showed. but i wonder does it able to deliver voltage value from SNMP (oid). could you please try snmpwalk?
many thanks..
Sure thing; here you are.
Doesn’t look like there’s anything health-specific, unfortunately.
iso.3.6.1.2.1.1.1.0 = STRING: "RB260GSP"
iso.3.6.1.2.1.1.2.0 = OID: iso.3.6.1.4.1.14988.2
iso.3.6.1.2.1.1.3.0 = Timeticks: (57980730) 6 days, 17:03:27.30
iso.3.6.1.2.1.1.4.0 = STRING: ""
iso.3.6.1.2.1.1.5.0 = STRING: ""
iso.3.6.1.2.1.1.6.0 = ""
iso.3.6.1.2.1.1.7.0 = INTEGER: 2
iso.3.6.1.2.1.2.1.0 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.1.1 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.1.2 = INTEGER: 2
iso.3.6.1.2.1.2.2.1.1.3 = INTEGER: 3
iso.3.6.1.2.1.2.2.1.1.4 = INTEGER: 4
iso.3.6.1.2.1.2.2.1.1.5 = INTEGER: 5
iso.3.6.1.2.1.2.2.1.1.6 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.2.1 = STRING: "Port1"
iso.3.6.1.2.1.2.2.1.2.2 = STRING: "Port2"
iso.3.6.1.2.1.2.2.1.2.3 = STRING: "Port3"
iso.3.6.1.2.1.2.2.1.2.4 = STRING: "Port4"
iso.3.6.1.2.1.2.2.1.2.5 = STRING: "Port5"
iso.3.6.1.2.1.2.2.1.2.6 = STRING: "SFP"
iso.3.6.1.2.1.2.2.1.3.1 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.2 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.3 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.4 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.5 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.3.6 = INTEGER: 6
iso.3.6.1.2.1.2.2.1.4.1 = INTEGER: 1500
iso.3.6.1.2.1.2.2.1.4.2 = INTEGER: 1500
iso.3.6.1.2.1.2.2.1.4.3 = INTEGER: 1500
iso.3.6.1.2.1.2.2.1.4.4 = INTEGER: 1500
iso.3.6.1.2.1.2.2.1.4.5 = INTEGER: 1500
iso.3.6.1.2.1.2.2.1.4.6 = INTEGER: 1500
iso.3.6.1.2.1.2.2.1.5.1 = Gauge32: 1000000000
iso.3.6.1.2.1.2.2.1.5.2 = Gauge32: 1000000000
iso.3.6.1.2.1.2.2.1.5.3 = Gauge32: 1000000000
iso.3.6.1.2.1.2.2.1.5.4 = Gauge32: 1000000000
iso.3.6.1.2.1.2.2.1.5.5 = Gauge32: 1000000000
iso.3.6.1.2.1.2.2.1.5.6 = Gauge32: 10000000
iso.3.6.1.2.1.2.2.1.6.1 = Hex-STRING: 4C 5E 0C F5 05 32
iso.3.6.1.2.1.2.2.1.6.2 = Hex-STRING: 4C 5E 0C F5 05 32
iso.3.6.1.2.1.2.2.1.6.3 = Hex-STRING: 4C 5E 0C F5 05 32
iso.3.6.1.2.1.2.2.1.6.4 = Hex-STRING: 4C 5E 0C F5 05 32
iso.3.6.1.2.1.2.2.1.6.5 = Hex-STRING: 4C 5E 0C F5 05 32
iso.3.6.1.2.1.2.2.1.6.6 = Hex-STRING: 4C 5E 0C F5 05 32
iso.3.6.1.2.1.2.2.1.7.1 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.2 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.3 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.4 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.5 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.7.6 = INTEGER: 2
iso.3.6.1.2.1.2.2.1.8.1 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.8.2 = INTEGER: 2
iso.3.6.1.2.1.2.2.1.8.3 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.8.4 = INTEGER: 2
iso.3.6.1.2.1.2.2.1.8.5 = INTEGER: 2
iso.3.6.1.2.1.2.2.1.8.6 = INTEGER: 2
iso.3.6.1.2.1.2.2.1.9.1 = Timeticks: (15683647) 1 day, 19:33:56.47
iso.3.6.1.2.1.2.2.1.9.2 = Timeticks: (14974828) 1 day, 17:35:48.28
iso.3.6.1.2.1.2.2.1.9.3 = Timeticks: (15037411) 1 day, 17:46:14.11
iso.3.6.1.2.1.2.2.1.9.4 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.2.2.1.9.5 = Timeticks: (14969913) 1 day, 17:34:59.13
iso.3.6.1.2.1.2.2.1.9.6 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.2.2.1.10.1 = Counter32: 560376253
iso.3.6.1.2.1.2.2.1.10.2 = Counter32: 5078798
iso.3.6.1.2.1.2.2.1.10.3 = Counter32: 31728454
iso.3.6.1.2.1.2.2.1.10.4 = Counter32: 0
iso.3.6.1.2.1.2.2.1.10.5 = Counter32: 129811
iso.3.6.1.2.1.2.2.1.10.6 = Counter32: 0
iso.3.6.1.2.1.2.2.1.11.1 = Counter32: 422292
iso.3.6.1.2.1.2.2.1.11.2 = Counter32: 44677
iso.3.6.1.2.1.2.2.1.11.3 = Counter32: 541450
iso.3.6.1.2.1.2.2.1.11.4 = Counter32: 0
iso.3.6.1.2.1.2.2.1.11.5 = Counter32: 544
iso.3.6.1.2.1.2.2.1.11.6 = Counter32: 0
iso.3.6.1.2.1.2.2.1.12.1 = Counter32: 4497794
iso.3.6.1.2.1.2.2.1.12.2 = Counter32: 19473
iso.3.6.1.2.1.2.2.1.12.3 = Counter32: 234
iso.3.6.1.2.1.2.2.1.12.4 = Counter32: 0
iso.3.6.1.2.1.2.2.1.12.5 = Counter32: 1887
iso.3.6.1.2.1.2.2.1.12.6 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.1 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.2 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.3 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.4 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.5 = Counter32: 0
iso.3.6.1.2.1.2.2.1.13.6 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.1 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.2 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.3 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.4 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.5 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.6 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.1 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.2 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.3 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.4 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.5 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.6 = Counter32: 0
iso.3.6.1.2.1.2.2.1.16.1 = Counter32: 60715578
iso.3.6.1.2.1.2.2.1.16.2 = Counter32: 21340241
iso.3.6.1.2.1.2.2.1.16.3 = Counter32: 513377965
iso.3.6.1.2.1.2.2.1.16.4 = Counter32: 0
iso.3.6.1.2.1.2.2.1.16.5 = Counter32: 832229
iso.3.6.1.2.1.2.2.1.16.6 = Counter32: 0
iso.3.6.1.2.1.2.2.1.17.1 = Counter32: 411947
iso.3.6.1.2.1.2.2.1.17.2 = Counter32: 20130
iso.3.6.1.2.1.2.2.1.17.3 = Counter32: 172405
iso.3.6.1.2.1.2.2.1.17.4 = Counter32: 0
iso.3.6.1.2.1.2.2.1.17.5 = Counter32: 14
iso.3.6.1.2.1.2.2.1.17.6 = Counter32: 0
iso.3.6.1.2.1.2.2.1.18.1 = Counter32: 31040
iso.3.6.1.2.1.2.2.1.18.2 = Counter32: 265571
iso.3.6.1.2.1.2.2.1.18.3 = Counter32: 4242684
iso.3.6.1.2.1.2.2.1.18.4 = Counter32: 0
iso.3.6.1.2.1.2.2.1.18.5 = Counter32: 11089
iso.3.6.1.2.1.2.2.1.18.6 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.1 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.2 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.3 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.4 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.5 = Counter32: 0
iso.3.6.1.2.1.2.2.1.19.6 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.1 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.2 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.3 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.4 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.5 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.6 = Counter32: 0
End of MIB
I couldn’t find it when I looked a few weeks back … Mostly switching to Ros based now… Eg hex poe and eventually the new 8 and 24 port ones
Sent from my Pixel XL using Tapatalk
Hi Aholmes,
after spent minutes to check voltage OID on my RB750Gr2, i found this OID which this OID could be found with the snmp OID you provided.
but i wonder if my point of view is correct. i may buy it one. :smiley:
last, i hope MikroTik staff could help me to confirm.
Thanks Aholmes for helps. +1 sent :smiley:
HI Efaden,
i need the small one due to limited power availability, we are using some batteries to supplying power so need the small one. but i hope RB260GSP could give us the solution.
thanks.
