what precision volts RB1000, this is works in volts the 12v at 48v?
This show only title datasheet 12v,
In rb433 used 12v at 48v…
What volts I can used in me RB1000?
I think it is 12-28V
And RB433 runs on the same…
12V and ONLY that
You mean 12V like recommended, but 10-28V is possible use if customer replace according CPU fan. Fan voltage=Input voltage
I pretender used in Batery of car, this have 13,4v more ocilant at 11,1v. I like know if I can used this batery ofcar in my RB1000?
You have gigabit network on your car?! Of course you can use 11,1V likewise 13,4V but I not sure that RB not reboot when you start engine
If you not help… then you silent ok…
I like know if used the batery of car… off course what not used RB1000 in car… I aliment power the RB 1000 with batery of car…
as he said, it should work
do you not precision in informacion? because if this rb1000 not works with volts, then I will have pay one new… Here in Brazil this rb1000 is very very very value…
Yes it work from 10,8V to 13,4V. Tested and approved!
do you have more information of test running rb1000 of volts 10,8 end 14,4?
