Vonage, Hotspot and MT
Hello everybody,
Here’s my situation…
I have setup an MT 3.0beta9 licence 5 setup in an Intel P4 with 512Mb RAM and a 40Gb HD as a controller and Hotspot with 1 AP/WDS on the roof as a APBridge and 2 133c CPE set as AP Bridge with WDS, one at 300 mts from main AP and one at 2000 mts from main AP…
If I just plug in the AP directly to the ADSL router the router does its thing and hands out ips and allows anybody to just log in to the internet.
Now i put the controller in the middle with one eth port conected to the dsl router and the other one setup as a Hotspot DHCP server handing out 10.5.50.0/24 ips.
It all goes fine… user profiles for 128, 512 and 1024 Kb work…
BUT, vonage device logging in with mac auth logs in no problem, the customer can hear me perfect but i cant hear him… tried every possible setup and change (probably not every otherwise it would have worked) to no avail…
I know there is a way to do it… I have seen it in another place but the instructions are not too clear…
Please, i need help to find the config for Qeue trees and Mangles…
Best regards from mexico
Nemecio
Just an update…
After 3 days of the same problem and after i posted the prior message the system started to work all of a sudden. I did nothing, changed nothing… Maybe the TELCO was playing aroud with the ports or something…
I still need the rules and mangles to give VoIP priority…
Would appreaciate any help…
Saludos de México…
