Aug 12 11:57:58 httpd.webservices(20577) INFO: handling radius autz request: from switch_ip => 1.2.3.4, connection_type => Wireless-802.11-NoEAP,switch_mac => d4:ca:6d:d2:88:67, mac => my.ip.on.em.ac, port => 0, username => my.ip.on.em.ac (pf::radius::authorize)
Aug 12 11:57:58 httpd.webservices(20577) INFO: MAC: my.ip.on.em.ac is of status unreg; belongs into registration VLAN (pf::vlan::getRegistrationVlan)
Aug 12 11:57:58 httpd.webservices(20577) INFO: [1.2.3.4] Returning ACCEPT with VLAN 2000 and role (pf::Switch::Mikrotik::returnRadiusAccessAccept)
Put this in /usr/share/freeradius/dictionary.mikrotik at the end of the attribute section
ATTRIBUTE MIKROTIK_WIRELESS_VLANID 26 integer
ATTRIBUTE MIKROTIK_WIRELESS_VLANIDTYPE 27 integer
cp /usr/local/pf/lib/pf/Switch/Hostapd.pm /usr/local/pf/lib/pf/Switch/Mikrotik.pm
chown pf:pf /usr/local/pf/lib/pf/Switch/Mikrotik.pm
patch Mikrotik.pm with the following diff.
Configure CAPSMAN controller in PF as a Mikrotik with radius deauthentication, setup your roles, radius secrets, etc.
Capsman Config:
# aug/12/2014 11:50:23 by RouterOS 6.18
# software id = 18QF-P0PP
add l2mtu=1600 name=BR-CAPS protocol-mode=none
/interface vlan
#Dunno if you really need these or not.. But Whatevs...
add interface=BR-CAPS name=default vlan-id=1208
add interface=BR-CAPS name=registration vlan-id=2000
add interface=BR-CAPS name=isolation vlan-id=2001
/caps-man datapath
add bridge=BR-CAPS client-to-client-forwarding=yes name=datapath1
/caps-man interface
add arp=enabled configuration.mode=ap configuration.ssid=LOSERTEST datapath=datapath1 disabled=no l2mtu=1600 mac-address=MACOFAP master-interface=none mtu=1500 name=cap1 radio-mac=MACOFAP
/caps-man aaa
set interim-update=5m
/caps-man access-list
add action=query-radius radius-accounting=yes signal-range=-120..120 time=0s-1d,sun,mon,tue,wed,thu,fri,sat
/caps-man manager
set enabled=yes
add bridge=BR-CAPS interface=ether13
add address=1.2.3.4/16 interface=ether12
add distance=1 gateway=x.y.z
/radius
add address=pfip secret=yoursecret service=wireless src-address=1.2.3.4
/radius incoming
set accept=yes
Patch:
--- Hostapd.pm 2014-06-26 15:03:13.000000000 -0400
+++ Mikrotik.pm 2014-08-12 11:46:13.305173223 -0400
@@ -1,17 +1,17 @@
-package pf::Switch::Hostapd;
+package pf::Switch::Mikrotik;
=head1 NAME
-pf::Switch::hostapd
+pf::Switch::mikrotik
=head1 SYNOPSIS
-The pf::Switch::hostapd module manages access to hostapd
+The pf::Switch::Mikrotik module manages access to mikrotik APs
=head1 STATUS
-Should work on the hostapd version started 2.0
+Should work on CAPSMAN enabled APs, tested on v6.18
=cut
@@ -25,7 +25,7 @@
use base ('pf::Switch');
use pf::config;
-sub description { 'Hostapd' }
+sub description { 'Mikrotik' }
# importing switch constants
use pf::Switch::constants;
@@ -192,7 +192,39 @@
return;
+sub returnRadiusAccessAccept {
+ my ($self, $vlan, $mac, $port, $connection_type, $user_name, $ssid, $wasInline, $user_role) = @_;
+ my $logger = Log::Log4perl::get_logger( ref($self) );
+ # Inline Vs. VLAN enforcement
+ my $radius_reply_ref = {};
+ my $role = "";
+ if ( (!$wasInline || ($wasInline && $vlan != 0) ) && isenabled($self->{_VlanMap})) {
+ $radius_reply_ref = {
+ 'MIKROTIK_WIRELESS_VLANID' => $vlan,
+ 'MIKROTIK_WIRELESS_VLANIDTYPE' => "0",
+ if ( isenabled($self->{_RoleMap}) && $self->supportsRoleBasedEnforcement()) {
+ $logger->debug("[$self->{'_id'}] Network device supports roles. Evaluating role to be returned");
+ if ( defined($user_role) && $user_role ne "" ) {
+ $role = $self->getRoleByName($user_role);
+ if ( defined($role) && $role ne "" ) {
+ $radius_reply_ref->{$self->returnRoleAttribute()} = $role;
+ $logger->info(
+ "[$self->{'_id'}] Added role $role to the returned RADIUS Access-Accept under attribute " . $self->returnRoleAttribute()
+ else {
+ $logger->debug("[$self->{'_id'}] Received undefined role. No Role added to RADIUS Access-Accept");
+ $logger->info("[$self->{'_id'}] Returning ACCEPT with VLAN $vlan and role $role");
+ return [$RADIUS::RLM_MODULE_OK, %$radius_reply_ref];
=back
=head1 AUTHOR
Maybe you’d like to tell me again how much I don’t know about packet fence… Moron.
