VPLS between ros 6 and ros 7
I’m having trouble establishing a VPLS between two routers with different versions: ros 6 and ros 7.
Is there a way?
Thanks.
Yes it does work. Post your /interface vpls export and /mpls export
No one’s going to be able to help you unless you provide info.
Solved.
I changed the PW L2MTU and it’s working.
Thank you.
