VPLS IP confussing-need help
Hi
I’ve got 3 networks on 2 routerboards and want to make a link using VPLS, but it gets confussed with all the IP’s on each device.
on each device I’ve got the following IP ranges active
#1 = 10.0.0.0/16 -vpn network
#2 = 10.10.0.0/16 -main network
#3 = 192.168.1.0/24 -managed port network
but it only works if I disable #1 on both devices, I only want to use #2 network for this operation, so is there any way to slap! this thing into working? ..because its really annoying me, becuase I need my vpn network active but not for vpls activaty
Just a pity that EoIP is unstable when you unplug the cable between the 2 routers
My old EoIP thread of me moaning about EoIP http://forum.mikrotik.com/t/eoip-issue-possible-bug/68090/1
You should run VPLS on loopback addresses.
I dont see where the loopback addresses are?
…I dont have any other options, because EoIP have lost its mind, and I dont know how to fix that issue and with “IP Tunnel” i cant do jack with, because I can add it in a bridge http://forum.mikrotik.com/t/eoip-issue-possible-bug/68090/1
Look at this guide
http://wiki.mikrotik.com/wiki/Manual:MPLSVPLS
No success mate, vpls suck. I really think mikrotik should fix the EoIP issue that I moaned about, v6.2 doesnt make it any better tho
