I have VPLS link between routers and I get packet drops, the usual ping might come back with 2 drops in 1,000 pings, when we use cisco rapid ping i get more errors, how can i check with Mikrotik packet drops? the fiber connecting these routers has no drops.
just ping with “dont fragment” option set. Start with a payload if 1472 bytes (ICMP & IP Header is 28 bytes in total, so you have a size of 1500 bytes).
Then, decrease payload size till ping goes through unfragmented.
Take the value of your payload and add 28. Thats you actual MTU.
Edit: Mke sure, all devices in the MPLS path support the resulting MTU of the MPLS frames. If you like to transport full 1500 bytes inside MPLS, you need an “outer” MTU of 1522 bytes and if you like to use 802.1q you need additional 4 bytes, so 1526 bytes in total.
mtr from linux pc?
None of the device has high CPU, most are between 20-30% rest of them 8%
no rate limit icmp
at the moment we are testing with icmp and seeing these packet loss, no loss on interface stats.
I have used the latest ROS version, and still this occurs.
