thesimj
February 26, 2009, 11:33pm
1
Hello!
Today i am start to testing RB433AH and enabled package mpls.
Configure ospf, mplsm and start to add vpls interface, but when i press button “ok” in winbox, nothing change.
But the my router is freezing, i reboot router (by power off/on), and start to add vpls interface in console, same situation.
I got another router x86 Alix 3c1 and do the same (MK.3.20).. results : equal. router is freezing, and only power off will helps.
strange problem, anybody test VPLS on MK.3.20
P.S. Hello to MUM, from Odessa . Bad that i am not drive to MUM. Maybe next year.
uldis
February 27, 2009, 12:44pm
2
Try mpls-test and routing-test package.It should work.
when i add VPLS interface in console show this error message
On version MK.3.17 all work fine , on ver. MK.3.18 and later hang with errors.
$ 4 : c79960d0 c700ba7c 00000000 c700ba78
$ 8 : 000005dc c7865048 00000000 05d10000
$12 : 00080014 c700be54 00000000 0000000e
$16 : 00000000 00000000 c79960d0 c72cec00
$20 : 00000005 c7865000 00000004 00000000
$24 : 00000000 c7330a40
$28 : c700a000 c700ba68 00000040 c026cbf4
Hi : 00000000
Lo : 00000000
epc : c026cc58 rtnl_fill_ifinfo+0x1d8/0x4e0
Tainted: P
ra : c026cbf4 rtnl_fill_ifinfo+0x174/0x4e0
Status: 1000f603 KERNEL EXL IE
Cause : 00800008
BadVA : 00000010
PrId : 00019374 (MIPS 24K)
Process route (pid: 844, threadinfo=c700a000, task=c7862b70, tls=00000000)
Stack : 00000000 c01d1c60 c019ade0 c0168d20 000005dc c026d1f4 00000150 c7802cc0
000000d0 c025852c c034c5b4 00000000 c7aa4a80 c72cee98 c72cec00 c79960d0
00000010 ffffffff 00000005 0000000e 00000004 c026d21c c72cef44 c72cee30
00000000 c72cee98 00000000 ffffffff 00000000 c02328f8 c034bfb0 fffffffe
00000000 c72cec00 c026d338 0000000f c034c41c 00000000 c78951b8 c72cee30
Call Trace:
[<c026cc58>] rtnl_fill_ifinfo+0x1d8/0x4e0
[<c026d21c>] rtmsg_ifinfo+0x70/0x11c
[<c026d338>] rtnetlink_event+0x70/0x80
[<c014332c>] notifier_call_chain+0x48/0xa4
[<c0143448>] raw_notifier_call_chain+0x14/0x20
[<c02613a4>] register_netdevice+0x470/0x4d0
[<c7317b14>] mpls_pw_add+0x34c/0xe6c [mpls]
[<c73150a4>] mpls_nl_init+0x25c/0xef8 [mpls]
Code: 044000b5 00000000 8e700180 <8e020010> 1040000d 00000000 8c440010 0c08
20ff 24840008
---[ end trace d54575d606cfd1f6 ]---
anybody help here?
it’s only my problem, or anybody have this problem with ROS 3.18+
This is known (old) problem. Make sure you use latest routing-test & mpls-test.
mmm, I’m not sure
I have the same issue, I downgrade to the version 3.17 and all is fine again
I made the downgrade through netinstall, the donwgrade via packages don’t work
I use OSPF, MPLS and VPLS and the new versions don’t work for me
diegotormes:
mmm, I’m not sure
How works MPLS & VPLS? stable?
