vpls problem
i have started to use mpls/vpls, i have all board with last package test (version 3.23), mpls work fine. but when i create a vpls i have this situation :
router A vpls interface:
remote-label: 109431
local-label: 1974
remote-status:
transport: 172.16.250.11/32
transport-nexthop: 172.16.0.229
imposed-labels: 151028,109431
but router B report this :
local-label: 109431
this not receive labels :-/ and the interface not running :-/
ldp is operative
A:
2 DOTV 172.16.250.11 172.16.250.1 172.16.250.11:0 yes 172.16.0.118
172.16.0.125
172.16.10.2
172.16.250.11
B:
TRANSPORT LOCAL-TRANSPORT PEER SEND-TARGETED ADDRESSES
0 DOTV 172.16.250.1 172.16.250.11 172.16.250.1:0 yes 172.16.0.235
172.16.250.1
Can you help me ?
FR4
Hi have also add TE support, the TE support works
Router A :
tunnel-id: 1
primary-path-state: established
primary-path: dyn
secondary-path-state: not-necessary
active-path: dyn
active-lspid: 1
active-label: 159478
explicit-route: “S:172.16.0.117/32,S:172.16.0.229/32,S:172.16.0.235/32”
recorded-route: “172.16.0.229[159478],172.16.0.235[0]”
reserved-bandwidth: 20.0Mbps
Router B
tunnel-id: 1
primary-path: dyn
active-path: dyn
active-lspid: 1
active-label: 159474
explicit-route: “S:172.16.0.229/32,S:172.16.0.117/32,S:172.16.0.118/32”
recorded-route: “172.16.0.117[159474],172.16.0.118[0]”
but VLPS not work
router A ← not work
local-label: 110697
router B
remote-label: 110699
local-label: 3500
remote-status:
transport: teRaddish
imposed-labels: 159474,110699
It is a bug ? can i downgrade to 3.22 ? I’m confused :cry:
You should post your routes and LDP bindings for both B&A - most likely routing in the non-working direction is set up differently - e.g. B can only reach A over default route and you are not distributing bindings for that, or something else with route from B to A.
Thanks for response in this post the config for ospf and mpls, for routing table i have 608 routes and in some router 2600 remote-binding where is the line that you need for troubleshout ?
router A
/routing ospf instance print
name=“default” router-id=172.16.250.11 distribute-default=if-installed-as-type-2 redistribute-connected=as-type-1 redistribute-static=no
redistribute-rip=no redistribute-bgp=no redistribute-other-ospf=no metric-default=1 metric-connected=20 metric-static=20 metric-rip=20 metric-bgp=20
metric-other-ospf=auto mpls-te-area=backbone mpls-te-router-id=loopback
/routing ospf network print
0 172.16.0.116/30 backbone
1 172.16.10.0/28 backbone
2 172.16.0.124/30 backbone
/interface print
0 R wlan1 wlan 1500
1 wlan2 wlan 1500
2 wlan3 wlan 1500
3 R ether1 ether 1500
4 X ether2 ether 1500
5 X ether3 ether 1500
6 R loopback bridge 1500
7 R pop bridge 1500
8 vplsGoku vpls 1500
9 X eoipGoku eoip-tunnel 1500
10 teGoku traffic-eng 1500
/ip address print
0 172.16.0.118/30 172.16.0.116 172.16.0.119 wlan1
1 172.16.10.2/28 172.16.10.0 172.16.10.15 ether1
2 172.16.0.125/30 172.16.0.124 172.16.0.127 wlan2
3 172.16.250.11/32 172.16.250.11 172.16.250.11 loopback
/interface bridge print
0 R name=“loopback” mtu=1500 arp=enabled mac-address=00:00:00:00:00:00 protocol-mode=none priority=0x8000 auto-mac=yes admin-mac=00:00:00:00:00:00
max-message-age=20s forward-delay=15s transmit-hold-count=6 ageing-time=5m
1 R name=“pop” mtu=1500 arp=enabled mac-address=00:00:00:10:01:11 protocol-mode=none priority=0x8000 auto-mac=yes admin-mac=00:00:00:00:00:00
/interface bridge port print
0 I wlan3 pop 0x80 10 none
1 I eoipGoku pop 0x80 10 none
2 I vplsGoku pop 0x80 10 none
/mpls ldp print
enabled: yes
lsr-id: 172.16.250.11
transport-address: 172.16.250.11
path-vector-limit: 255
hop-limit: 255
loop-detect: yes
use-explicit-null: no
distribute-for-default-route: no
/mpls ldp interface print
0 wlan1 5s 15s
1 ether1 5s 15s
2 wlan2 5s 15s
/mpls traffing-eng interface print
0 wlan1 20Mbps 1 20.0Mbps
/interface traffing-eng print
name=“teGoku” mtu=1500 disable-running-check=no from-address=172.16.250.11 to-address=172.16.250.1 bandwidth=100kbps primary-path=dyn
primary-retry-interval=1m record-route=yes bandwidth-limit=disabled auto-bandwidth-range=0bps auto-bandwidth-reserve=0%
auto-bandwidth-avg-interval=5m auto-bandwidth-update-interval=1h
/interface vpls print
0 name=“vplsGoku” mtu=1500 mac-address=00:00:00:10:01:11 arp=enabled disable-running-check=no remote-peer=172.16.250.1 vpls-id=10:0 cisco-style=no
cisco-style-id=0
Router B
0 name=“default” router-id=172.16.250.1 distribute-default=never
metric-bgp=auto metric-other-ospf=auto mpls-te-area=backbone
/routing ospf networks print
0 172.16.0.224/28 backbone
1 192.168.123.0/24 backbone
/interface print
0 R ;;; backbone
ether1 ether 1500
1 X ;;; iscsi
ether5 ether 1500
2 R ;;; LoopBack
3 R ;;; mz
ether2 ether 1500
4 X ;;; dmz
ether3 ether 1500
5 R ;;; wan
ether4 ether 1500
6 R pop bridge 1500
7 R vplsRaddish vpls 1500
8 R teRaddish traffic-eng 1500
9 X teCrili traffic-eng 1500
10 X teTensing traffic-eng 1500
11 X vplsTensing vpls 1500
12 X eoipRyuShenron eoip-tunnel 1500
13 X vplsCrili vpls 1500
14 X eoipRaddish eoip-tunnel 1500
15 X eoipDarbula eoip-tunnel 1500
16 X eoipCrili eoip-tunnel 1500
17 X eoipRianShenron eoip-tunnel 1500
18 R teRouter3 traffic-eng 1500
19 R vplsRouter3 vpls 1500
/ip address print
0 172.16.0.235/28 172.16.0.224 172.16.0.239 ether1
1 172.16.250.1/32 172.16.250.1 172.16.250.1 loopback
2 X 172.16.1.126/25 172.16.1.0 172.16.1.127 ether2
3 X 172.16.1.254/25 172.16.1.128 172.16.1.255 ether3
4 X 172.16.0.249/29 172.16.0.248 172.16.0.255 ether4
5 X 192.168.0.254/24 192.168.0.0 192.168.0.255 ether5
6 192.168.123.1/24 192.168.123.0 192.168.123.255 ether2
0 R ;;; LoopBack
admin-mac=00:00:00:00:00:00 max-message-age=20s forward-delay=15s
1 R name=“pop” mtu=1500 arp=enabled mac-address=00:00:00:00:00:00
0 I eoipRyuShenron pop 0x80 10 none
1 I eoipRaddish pop 0x80 10 none
2 X vplsCrili pop 0x80 10 none
3 X vplsRaddish pop 0x80 10 none
4 X vplsTensing pop 0x80 10 none
5 I eoipDarbula pop 0x80 10 none
6 I eoipCrili pop 0x80 10 none
7 I eoipRianShenron pop 0x80 10 none
/mpls ldp print
enabled: yes
hop-limit: 255
loop-detect: yes
0 ether1 5s 15s
1 ether2 5s 15s
/mpls traffic-eng interface print
0 ether1 100Mbps 1 95.0Mbps
1 ether2 100Mbps 1 100.0Mbps
/interface traffic-eng print
0 R name=“teRaddish” mtu=1500 disable-running-check=no
from-address=172.16.250.1 to-address=172.16.250.11 bandwidth=5Mbps
primary-path=dyn primary-retry-interval=1m record-route=yes
auto-bandwidth-reserve=0% auto-bandwidth-avg-interval=5m
1 X name=“teCrili” mtu=1500 disable-running-check=no
from-address=172.16.250.1 to-address=172.16.250.8 bandwidth=10Mbps
2 X name=“teTensing” mtu=1500 disable-running-check=no
from-address=172.16.250.1 to-address=172.16.250.9 bandwidth=10Mbps
3 R name=“teRouter3” mtu=1500 disable-running-check=no
from-address=172.16.250.1 to-address=172.16.250.101 bandwidth=0bps
0 R name=“vplsRaddish” mtu=1500 mac-address=00:00:00:10:11:01 arp=enabled
disable-running-check=no remote-peer=172.16.250.11 vpls-id=10:0
cisco-style=no cisco-style-id=0
1 X name=“vplsTensing” mtu=1500 mac-address=00:00:00:10:09:01 arp=enabled
disable-running-check=no remote-peer=172.16.250.9 vpls-id=10:0
2 X name=“vplsCrili” mtu=1500 mac-address=00:00:00:10:08:01 arp=enabled
disable-running-check=no remote-peer=172.16.250.8 vpls-id=10:0
3 R name=“vplsRouter3” mtu=1500 mac-address=02:61:D1:CF:26:E4 arp=enabled
disable-running-check=no remote-peer=172.16.250.101 vpls-id=10:0
have the same problem here
one router the vpls interface is running the other one not..
