VPLS Tunnel between different areas
we would like to switch from EoIP to VPLS, but we encounter some serious problems with it.
If we try to establish a VPLS tunnel between 172.16.2.1 and 172.21.0.1 (or some other device in this area), the tunnel doesn’t entry the running state.
Otherwise, a tunnel within an area works perfectly.
You can see a simplified network diagram in the attached image.
The problem seems to be at the border router (172.16.3.1 in this case).
Now let me describe our setup.
All our routers are running on 4.17.
As you can see, the OSPF is splitted in 4 different areas.
The backbone area is located in a house, all devices are connected with ethernet cables.
The connections between the border area routers and the individual areas are established with wireless.
Each area (17, 18 and 21) contains ~10-20 routerboards.
configuration @ 172.16.2.1
/routing ospf instance print
Flags: X - disabled
 0   name="default" router-id=172.16.2.1 distribute-default=never redistribute-connected=no redistribute-static=no redistribute-rip=no redistribute-bgp=no  redistribute-other-ospf=no metric-default=1 metric-connected=20 metric-static=2000 metric-rip=20 metric-bgp=20 metric-other-ospf=20 in-filter=ospf-in out-filter=ospf-out
/routing ospf area print
 #   NAME               AREA-ID         TYPE    DEFAULT-COST
 1   backbone          0.0.0.0         default
 /routing ospf network print
 #   NETWORK            AREA
 0   172.16.0.0/16      backbone
 /mpls interface print
Flags: X - disabled
 #   INTERFACE    MPLS-MTU
 0   all                1508
/mpls ldp print
                       enabled: yes
                        lsr-id: 172.16.2.1
             transport-address: 172.16.2.1
             path-vector-limit: 255
                     hop-limit: 255
                   loop-detect: yes
             use-explicit-null: no
  distribute-for-default-route: no
  /mpls ldp interface print
 #   INTERFACE          HELLO-INTERVAL       HOLD-TIME
 1   ether1                5s                              15s
  /interface vpls print
Flags: X - disabled, R - running, D - dynamic, B - bgp-signaled, C - cisco-bgp-signaled
0     name="vpls1" mtu=1500 l2mtu=1500 mac-address=00:00:00:00:05:01 arp=enabled disable-running-check=no remote-peer=172.21.2.1 vpls-id=100:0
       cisco-style=no cisco-style-id=0 advertised-l2mtu=1500 pw-type=raw-ethernet
configuration @ 172.16.3.1
Flags: X - disabled
 0   name="default" router-id=172.16.3.1 distribute-default=never
     redistribute-connected=as-type-1 redistribute-static=no
     metric-default=1 metric-connected=20 metric-static=20 metric-rip=20
     metric-bgp=auto metric-other-ospf=auto in-filter=ospf-in
     out-filter=ospf-out
 0   bahrdorf                                0.0.0.21        default
 #   NETWORK            AREA
 1   172.21.0.0/16      bahrdorf
 /routing ospf area range print
Flags: X - disabled
 #   AREA                                 RANGE              COST       ADVERTISE
 0   bahrdorf                             172.21.0.0/16      calculated yes
 1   backbone                             172.16.0.0/16      calculated yes
Flags: X - disabled
 0   all        1508
 /mpls ldp print
                       enabled: yes
                        lsr-id: 172.16.3.1
             transport-address: 172.16.3.1
                     hop-limit: 255
                   loop-detect: no
 0   ether1                             5s                   15s
 1   wlan1                              5s                   15s
configuration @ 172.21.2.1
Flags: X - disabled
 0   name="default" router-id=172.21.2.1 distribute-default=never redistribute-connected=as-type-1
     metric-connected=20 metric-static=20 metric-rip=20 metric-bgp=auto metric-other-ospf=auto in-filter=ospf-in
     out-filter=ospf-out
 #   NETWORK            AREA
 0   172.21.0.0/16      bahrdorf
Flags: X - disabled
 0   all        1508
 /mpls ldp print
                       enabled: yes
                        lsr-id: 172.21.2.1
             transport-address: 172.21.2.1
                     hop-limit: 255
                   loop-detect: no
 0   wlan1        5s                   15s
 0     name="vpls1" mtu=1500 l2mtu=1500 mac-address=00:00:00:00:05:00 arp=enabled disable-running-check=no
       remote-peer=172.16.2.1 vpls-id=100:0 cisco-style=no cisco-style-id=0 advertised-l2mtu=1500
Hope we can figure out the problem together.
Best regards,
Sebastian
Probably MPLS LSP is “broken” on area border router. There is no limitation for VPLS to work between routers in different areas - actually MPLS (and therefore VPLS) does not care what IGP is used to exchange routes. What matters is that there must be “complete” MPLS LSP between VPLS endpoints and usually it means that all routers between VPLS endpoints MUST have /32 routes to VPLS endpoints. Make sure that area border routers are properly distributing /32 routes for VPLS endpoints into neighboring area.
To some extent this has been explained here: http://forum.mikrotik.com/t/why-cant-i-use-24-routes-for-ldp-and-vpls/33349/1
Hi Mplsguy,
thank you for your reply. I checked my configuration and noticed, that i’ve used /30 for loopback addresses. I changed it to /32 on all intermediate devices and now one side of the tunnel is running (@172.16.2.1).
Please have a look at the images, they show you the considerable routing entries, the remote binding list and the interface status.
Status @ 172.16.2.1
Status @ 172.21.2.1
The problem still exists… :frowning:
I try to setup a similar network using OSPF route summarization.
If a LSP has to be announced as /32 througout the whole network,
where is the sense in doing route summarization?
How can I just announce /32 loopback routes and still just summarize any /30 and /24 routes of a given area?
Give your routers loopback ip addresses in a different subnet than your link addresses.
