I am having a problem establishing a VPLS tunnel using a router as a hop. My architecture is relatively simple:
R1-e1 -------- e1-R2-e2 --------- e2-R3
I can however establish VPLS tunnels from Router1 to Router2 and Router2 to Router3 but not Router1 to Router3.
Router1:
add name=lo
set [ find default-name=ether1 ] l2mtu=2018
add address=192.168.255.1 interface=lo
add address=192.168.255.129/30 interface=ether1
/mpls interface
set [ find default=yes ] mpls-mtu=1992
/mpls ldp
set enabled=yes lsr-id=192.168.255.1 transport-address=192.168.255.1
/mpls ldp interface
add interface=ether1
/interface vpls
add advertised-l2mtu=1992 disabled=no mac-address=02:30:57:E2:B1:62 \
name=vpls-test remote-peer=192.168.255.3 vpls-id=3:0
Router2:
add name=lo
set [ find default-name=ether2 ] l2mtu=2018
add address=192.168.255.2 interface=lo
add address=192.168.255.130/30 interface=ether1
add address=192.168.255.141/30 interface=ether2
/mpls interface
/mpls ldp
set enabled=yes lsr-id=192.168.255.2 transport-address=192.168.255.2
/mpls ldp interface
add interface=ether2
Router3:
add name=lo
add address=192.168.255.3 interface=lo
add address=192.168.255.142/30 interface=ether2
/mpls interface
/mpls ldp
set enabled=yes lsr-id=192.168.255.3 transport-address=192.168.255.3
/mpls ldp interface
/interface vpls
add advertised-l2mtu=1992 disabled=no mac-address=02:D8:EB:D7:45:15 \
name=vpls-test remote-peer=192.168.255.1 vpls-id=3:0
When establishing largest packet size using ping between the routers:
Router1 (192.168.255.1) can ping Router2 (192.168.255.2) with 2018 byte packets:
[admin@Router1] > ping 192.168.255.2 do-not-fragment size=2018
SEQ HOST SIZE TTL TIME STATUS
0 192.168.255.2 2018 64 5ms
sent=1 received=1 packet-loss=0% min-rtt=5ms avg-rtt=5ms max-rtt=5ms
Router2 (192.168.255.2) can ping both Router1 (192.168.255.1) and Router3 (192.168.255.3) with 2018 byte packets:
[admin@Router2] > ping 192.168.255.1 do-not-fragment size=2018
0 192.168.255.1 2018 64 3ms
sent=1 received=1 packet-loss=0% min-rtt=3ms avg-rtt=3ms max-rtt=3ms
[admin@Router2] > ping 192.168.255.3 do-not-fragment size=2018
0 192.168.255.3 2018 64 2ms
sent=1 received=1 packet-loss=0% min-rtt=2ms avg-rtt=2ms max-rtt=2ms
Router3 (192.168.255.3) can ping Router2 (192.168.255.2) with 2018 byte packets:
[admin@Router3] > ping 192.168.255.2 do-not-fragment size=2018
0 192.168.255.2 2018 64 2ms
Router1 (192.168.255.1) can only ping Router3 with 1988 byte packets:
[admin@Router1] > ping 192.168.255.3 do-not-fragment size=1992
0 packet too large and cannot be fragmented
0 192.168.255.129 576 64 0ms fragmentation needed and DF set
sent=1 received=0 packet-loss=100%
[admin@Router1] > ping 192.168.255.3 do-not-fragment size=1988
0 192.168.255.3 1988 63 23ms
sent=1 received=1 packet-loss=0% min-rtt=23ms avg-rtt=23ms max-rtt=23ms
MPLS Forwaring table entries for loopback addresses on each of the routers:
Router1:
[admin@Router1] > mpls forwarding-table print detail where destination=192.168.255.3/32
Flags: L - ldp, V - vpls, T - traffic-eng
0 L in-label=520 out-labels=161 interface=ether1 nexthop=192.168.255.130 destination=192.168.255.3/32
Router2:
[admin@Router2] > mpls forwarding-table print detail where destination=192.168.255.1/32
0 L in-label=283 out-labels="" interface=ether1 nexthop=192.168.255.129 destination=192.168.255.1/32
[admin@Router2] > mpls forwarding-table print detail where destination=192.168.255.3/32
0 L in-label=161 out-labels="" interface=ether2 nexthop=192.168.255.142 destination=192.168.255.3/32
Router3:
[admin@Router3] > mpls forwarding-table print detail where destination=192.168.255.1/32
0 L in-label=89 out-labels=283 interface=ether2 nexthop=192.168.255.141 destination=192.168.255.1/32
I see nothing in the logs, VPLS simply doesn’t appear to want to connect:
[admin@Router1] > int vpls print detail
Flags: X - disabled, R - running, D - dynamic, B - bgp-signaled, C - cisco-bgp-signaled
0 ;;; Internet - Staff - DR:
name="vpls-test" mtu=1500 l2mtu=1992 mac-address=02:30:57:E2:B1:62 arp=enabled
arp-timeout=auto disable-running-check=no remote-peer=192.168.255.3 vpls-id=3:0 cisco-style=no cisco-style-id=0
advertised-l2mtu=1992 pw-type=raw-ethernet use-control-word=default
[admin@Router3] > int vpls print detail
0 ;;; Internet - Staff:
name="vpls-test" mtu=1500 l2mtu=1992 mac-address=02:D8:EB:D7:45:15 arp=enabled
arp-timeout=auto disable-running-check=no remote-peer=192.168.255.1 vpls-id=3:0 cisco-style=no cisco-style-id=0
