VPLS + Vlan Trunk... Weird Issue
Hey Guys,
I’m trying to run a PPPoE service here and having troubles. I have 2 routers and between them i’m running VPLS. One router is the edge router, the other is the PPPoE server.
When I set one of the ports on the edge router as a member of the VPLS bridge and try to PPPoE across to it, it works fine :slight_smile: Though If I set a VLAN on the switch to the router as the PPPoE port, it no longer works.
THe switch is a Cisco 2960 and the router is a MikroTik 750G.
Any ideas?
Raise the MTU limit on the switch and router, and possibly the Mikrotik.
Refer to this document.
http://wiki.mikrotik.com/wiki/Manual:Maximum_Transmission_Unit_on_RouterBoards
