VPN & 2 pppoe issue
maybe some of you great guys can help me with a small issue.
I have a the following configuration..
WAN - 2 PPPOE accounts
1st - is used to offer internet to my /24 LAN
2nd - used for one IP inside the LAN so it can have a different public IP.
For the 2nd IP a there is a mangle & route rule so the traffic can be routed the right way.
On the router i have OPENVPN setup, but for some reason i can’t access the IP though VNP that has the mangle rule (mark routing), if i disable it everything is ok.
Does anybody has clue how to solve this ?
Thanks.
Is the OpenVPN working?
Yes, the issue is with only the IP that goes out via another gateway.
You should probably post your config as this will give us a better idea of what you have done and where it can be fixed. Make sure to use “hide-sensitive” flag so no personal information is posted.
