I apologize if my question is repetitive, but until now I couldn't find a solution myself in the forum.
I also asked for assistance from the place where I bought the router, but they refused to assist me.
The situation is this, we have a HAP AC³ RBD53IG-5HACD2HND router that is in the office and I want to run a VPN server on it. All the laptops have VNC server installed and when I am on the local network there is no problem to access them over hostname. It's important to only access them by hostname because all laptops use an external docking station with a built-in LAN (there is one at every workstation), often times employees change docking stations and workstations and there is no way to put a fixed IP address on every laptop.
I managed to install a VPN server myself with access to the main network (dhcp) without needing to use a standalone. However, the problem is this: when I am out of the office and connect to the VPN server I can only access the laptops by IP address but not by hostname.
Can I also set up the router so that when I connect to the office with the VPN I can connect to the VNC servers on the laptops only by hostname?
I am applying my configuration at the moment, there may be things that are not right, but this is the first time I am encountering Mikrotik.
Thanks in advance for the assistance!
mar/08/2023 16:30:33 by RouterOS 7.6
software id = A9C8-6NKS
model = RBD53iG-5HacD2HnD
serial number = HCQ08234SS7
add admin-mac=18:FD:74:2F:8B:A9 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=5C:1A:6F:D6:53:30
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifiwave2 channel
add band=2ghz-n frequency=2412,2432,2462 name=2.4GHz width=20/40mhz
add band=5ghz-ac name=5GHz skip-dfs-channels=all width=20/40/80mhz
/interface wifiwave2 security
add authentication-types=wpa2-psk,wpa3-psk disable-pmkid=yes group-key-update=1h name=sec1
/interface wifiwave2 configuration
add chains=0,1 channel=2.4GHz country=Bulgaria mode=ap name="Conf 2.4GHz" security=sec1 ssid=PPViva1 tx-chains=0,1
add chains=0,1 channel=5GHz country=Bulgaria mode=ap name="Conf 5GHz" security=sec1 ssid=PPViva1 tx-chains=0,1
set [ find default-name=wifi1 ] channel=2.4GHz configuration="Conf 2.4GHz" configuration.mode=ap disabled=no security=sec1
set [ find default-name=wifi2 ] channel=5GHz configuration="Conf 5GHz" configuration.mode=ap disabled=no security=sec1
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp interface=bridge name=defconf
/ppp profile
set *FFFFFFFE bridge=bridge dns-server=192.168.88.1 local-address=192.168.88.1 remote-address=dhcp
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
/ip settings
set tcp-syncookies=yes
/interface l2tp-server server
set enabled=yes use-ipsec=yes
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.88.74 mac-address=00:21:04:0D:59:B6 server=defconf
add address=192.168.88.147 client-id=1:0:e0:4c:36:4d:a5 mac-address=00:E0:4C:36:4D:A5 server=defconf
add address=192.168.88.227 client-id=1:14:98:77:7a:c1:80 mac-address=14:98:77:7A:C1:80 server=defconf
add address=192.168.88.204 client-id=1:0:e0:4c:36:55:f8 mac-address=00:E0:4C:36:55:F8 server=defconf
add address=192.168.88.237 client-id=1:68:ff:7b:83:50:d6 mac-address=68:FF:7B:83:50:D6 server=defconf
add address=192.168.88.44 client-id=1:0:e0:4c:36:41:60 mac-address=00:E0:4C:36:41:60 server=defconf
add address=192.168.88.165 client-id=1:0:e0:4c:36:16:d0 mac-address=00:E0:4C:36:16:D0 server=defconf
add address=192.168.88.59 client-id=1:0:e0:4c:36:f6:33 mac-address=00:E0:4C:36:F6:33 server=defconf
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=input dst-port=1701,500,4500 in-interface-list=WAN protocol=udp
add action=accept chain=input in-interface-list=WAN protocol=ipsec-esp
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none src-address=192.168.88.0/24
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=192.168.89.0/24
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=2244
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/ppp secret
add name=vpn profile=default-encryption service=l2tp
/system clock
set time-zone-name=Europe/Sofia
/tool bandwidth-server
set authenticate=no enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
