VPN Access check box
I recently verified the check box next to VPN access in the Quick Setup section of the Winbox and since then I can not connect to the Mikrotik RB951G’2HnD.
The connection does not go through WinBox or over HTTP.
On the other hand, I can remotely connect to our server behind the router via VPN access (via 5d **********. sn.mynetname.net).
The question is how do I turn off VPN access in this situation?
if you can access the server, log in to the server, run winbox and access Mikrotik from the server, undo the change you made earlier.
