Hy
Some time ago i wrote about problem with my OpenVPN.
I have investigated a bit and foud. If i have 2 devices connected via OpenVPN or L2PT (both with the same VPN or each seperate). They see each other and i can access between them..
(example. Teltonika RUT950 connected with L2PT via SIM card can be accessed with laptop - connected thru mobile phone hotspot.. these works normaly)
The problem i am having is that if i want to access one of them thru my PC witch is connected directly to my router in LAN i cant access it. But in reverse works.. if i connect to VPN i can access my PC in LAN.
Examples:
My LAN setup: 192.168.1.0/24
Teltonika remote VPN IP: 192.168.1.73
Laptop remote VPN IP: 192.168.1.72
My PC in LAN IP: 192.168.1.10
Is there a problem with masqurade or route?
Sob
October 27, 2022, 5:46pm
2
It looks like missing proxy ARP on LAN interface and too broad masquerade rule that hides it, which works for one direction but not the other. But better post your config.
My configuration:
oct/27/2022 23:21:51 by RouterOS 6.47.10
software id = ZWRC-FBTF
model = RB4011iGS+5HacQ2HnD
serial number = D1460C19DA7E
add name=TV
add name=Telefon
add name=bridge1
add name=bridge_WiFi
/interface wireless
set [ find default-name=wlan1 ] country=slovenia disabled=no frequency=auto
mode=ap-bridge ssid=“Bezan 5G” station-roaming=enabled wireless-protocol=
802.11
set [ find default-name=wlan2 ] antenna-gain=50 band=2ghz-b/g/n
channel-width=20/40mhz-Ce country=japan disabled=no frequency=auto
frequency-mode=superchannel mode=ap-bridge ssid=Bezan station-roaming=
enabled wireless-protocol=802.11
/interface pppoe-client
add add-default-route=yes disabled=no interface=sfp-sfpplus1 name=pppoe-out1
password=xxxx use-peer-dns=yes user=xxxxx
/interface vlan
add interface=ether6 name=“TV BOX1” vlan-id=3999
add interface=ether7 name=“TV BOX2” vlan-id=3999
add interface=sfp-sfpplus1 name=“TV IN” vlan-id=3999
add interface=ether2 name=“TV NEO1” vlan-id=3999
add interface=sfp-sfpplus1 name=“Telefon IN” vlan-id=3998
add interface=ether4 name=“Telefon Out” vlan-id=3998
add name=vlan100 vlan-id=100
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods=“”
mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=
xxx wpa2-pre-shared-key=mobitel123
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256,sha1
add name=dhcp ranges=192.168.1.100-192.168.1.199
add name=dhcp_WiFi ranges=192.168.1.200-192.168.1.240
add address-pool=dhcp disabled=no interface=bridge1 name=dhcp1
add address-pool=dhcp_WiFi disabled=no interface=bridge_WiFi name=dhcp_WiFi
/lora servers
add address=eu.mikrotik.thethings.industries down-port=1700 name=TTN-EU
up-port=1700
add address=us.mikrotik.thethings.industries down-port=1700 name=TTN-US
up-port=1700
/ppp profile
add bridge=bridge1 local-address=192.168.1.1 name=vpn_profile
/tool user-manager customer
set admin access=
own-routers,own-users,own-profiles,own-limits,config-payment-gw
/user group
set full policy=“local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas
sword,web,sniff,sensitive,api,romon,dude,tikapp”
add bridge=bridge1 disabled=yes interface=ether4
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=ether10
add bridge=bridge1 interface=wlan1
add bridge=bridge1 interface=wlan2
add bridge=TV interface=“TV IN”
add bridge=TV interface=“TV BOX1”
add bridge=TV interface=“TV BOX2”
add bridge=Telefon interface=“Telefon IN”
add bridge=Telefon interface=“Telefon Out”
add bridge=TV interface=“TV NEO1”
/interface l2tp-server server
set default-profile=default enabled=yes ipsec-secret=luftP0st! use-ipsec=yes
add interface=sfp-sfpplus1 list=WAN
/interface ovpn-server server
set auth=sha1 certificate=server cipher=aes256 enabled=yes
require-client-certificate=yes
add address=192.168.1.1/24 interface=ether1 network=192.168.1.0
add address=192.168.100.1/24 disabled=yes network=192.168.100.0
/ip dhcp-client
add !dhcp-options interface=sfp-sfpplus1
/ip dhcp-server lease
add address=192.168.1.60 always-broadcast=yes mac-address=34:E1:D1:80:C0:F7
server=dhcp1
add address=192.168.1.61 mac-address=00:1E:42:4D:26:DC server=dhcp1
add address=192.168.1.0/24 dns-server=
192.168.1.1,193.189.160.13,193.189.160.23 gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes servers=193.189.160.13,193.189.160.23
/ip dns static
add address=192.168.1.26 comment=“MK Raubritter Spletna Stran” name=
mk-raubritter.com
add address=192.168.1.26 name=www.mk-raubritter.com
add address=192.168.1.26 comment=“Arja Spletna Stran” name=
pomoc-zivalim-arja.si
add address=192.168.1.26 name=www.pomoc-zivalim-arja.si
/ip firewall address-list
add address=192.168.1.70-192.168.0.79 disabled=yes list=VPN
add action=fasttrack-connection chain=forward disabled=yes
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=accept chain=input comment=“Allow t2p” in-interface=pppoe-out1
protocol=ipsec-esp
add action=accept chain=input dst-port=500,1701,4500 in-interface=pppoe-out1
protocol=udp
add action=accept chain=input comment=OpenVPN dst-port=1194 protocol=tcp
add action=accept chain=input dst-port=80,443,8291 protocol=tcp src-address=
192.168.1.0/24
add action=drop chain=“log and drop” disabled=yes
add action=jump chain=input disabled=yes jump-target=“log and drop”
add action=drop chain=input in-interface-list=!LAN
/ip firewall mangle
add action=route chain=prerouting disabled=yes dst-address-list=!VPN
passthrough=yes protocol=!icmp route-dst=192.168.1.1
add action=masquerade chain=srcnat comment=VPN src-address=192.168.1.0/24
add action=accept chain=dstnat disabled=yes dst-port=1194 protocol=udp
/ip upnp
set enabled=yes
/ppp secret
add local-address=192.168.1.1 name=rocky password=Passw0rd0 remote-address=
192.168.1.70
add local-address=192.168.1.1 name=teltonika password=Passw0rd0
remote-address=192.168.1.71
/system clock
set time-zone-name=Europe/Ljubljana
/system leds
add interface=wlan2 leds=“wlan2_signal1-led,wlan2_signal2-led,wlan2_signal3-le
d,wlan2_signal4-led,wlan2_signal5-led” type=wireless-signal-strength
add interface=wlan2 leds=wlan2_tx-led type=interface-transmit
add interface=wlan2 leds=wlan2_rx-led type=interface-receive
/tool mac-server
/tool mac-server mac-winbox
/tool user-manager database
set db-path=user-manager
Sob
October 27, 2022, 10:31pm
4
If only I could predict lottery numbers as easily as I can tell what’s wrong with configs that I don’t see.
This rule should not needed for anything:
But you need proxy ARP. Either on interface:
set [ find default-name=ether1 ] arp=proxy-arp
Or for individual addresses:
/ip arp
add interface=ether1 address=192.168.1.70 published=yes
add interface=ether1 address=192.168.1.71 published=yes
/interface
Etherne 1 - 10 are ethernet LAN ports? My PC is on Ethernet 3 port. So if i want to access VPN device (teltonika) witch has 192.168.1.71 remote address i should add arp: “add interface=ether1 address=192.168.1.71 published=yes” ?
Sob
October 27, 2022, 11:42pm
6
The interface should be bridge1. I originally went by IP address for LAN, which you have on ether1, but it should actually be on bridge1, because ether1 is bridge port, so LAN interface, as the router sees it, is bridge1.
I have tried both and thank you. When i set up in Bridge1 proxy-arp. it worked with L2PT and OpenVPN. i have also tried only in arp and same working resault.
