Hi, I has a Mikrotik (number 1) that has connected to internet (public IP address) and give internet access to other mikrotik (number 2), the second mikrotik is connected to the first through a private ip address such as 10.0.1.x but how I can create a VPN on the second Mikrotik?
I tried to enable /ip cloud on second mikrotik and create VPN profile but no success…
Because you have only one link to Internet with only one public ip it doesn’t have any sense what you are trying to. Just make port redirect to the second device as port 80 is already occupied by the first one.
Most likely, yes. There is more to the “puzzle” but that is different than what I thought in my head was goign on from your first post.
If your 2nd Mikrotik has a Public IP, I assume that Mikortik can reach the internet - correct?
You would just need to make sure that you have a NAT on the 2nd to allow traffic out and to ensure that the 1st Mikrotik isn’t blocking your VPN traffic.
