VPN and 2 WANs
Hi everybody
i wanna setup a PPTP client on my routerboard which is RB2001UiAS , also i m running a load balancing between two WANs on the same router , i wanna the PPTP client works on one of the WANs only , how can i specify that on the PPTP Client , i mean work only on WAN 1 for example ?
Add a Firewall Rule allowing the IP address of the remote VPN server via the Wan interface you want, and block the access to the another wan for the IP of the remote VPN server.
I has the same scenario and that’s what I do, but I don’t has Load balance.
Can you please show me how to do that.
and by IP do you mean the ip of the server or what since there is an IP for the PPTP server and also there is a dynamic IP given by that server
thanks a lot
