I am new to mikrotik os. I have never setup a vpn connection on any type router before. I have attempted to use various posts but I haven’t been successful. I need some suggestions on how to start the process. I also need some suggestions on how to troubleshoot/debug during the testing.
I have a mikrotik 2801 running 6.34.3. I didn’t set up this router/switch initially so I am not familiar on how that was done.
When I examine under NAT I don’t see the ISP ip address (its set up to receive ip via dhcp from ISP). The LAN is a private 192.168.x.x so I know it must be NATed somewhere, but in poke around in the config I can’t find it. I have been using the gui interface since learning the terminal will take more time.
I do see the NAT under firewall>nat. The setting is masquer. I know this is the active NAT since I see the interface that is connected to the ISP as the outgoing interface. But can’t see any listing of actually nating taking place, but I know it is.
So here are some questions.
- Do I need to create an ip pool for the vpn? I am assuming I do, am I correct in that I can use any private ip I want? 192.168.10.x for example.
- If I have the remote and local address in the ppp>secrets as 0.0.0.0 am I correct in that it will accept any address within the LAN and from outside the LAN?
Any other tips would be greatly appreciated…
