I need to connect three sites together using Mikrotik routers via ADSL lines. Two of the sites are already connected and I have both of their configs however I cant get to work the third site.
Would it be possible to help me if I had to upload the configs and a topology diagram?
The more info we get from you, the better we can advise you what to do.
Just a quick thought is that is should be possible to let 2 remote locations setup an individual VPN towards your main location.
The new (unconnected) location should setup a VPN towards the VPN server where the connected location is connecting to. With dedicated user/password credentials.
On the main site, you have to take care of the firewall filter rules to make sure the two remote locations can communicate or not. It’s up to you whether you want/need that or not.
Rudios many thanks for your help. Would it be possible to get in touch with you directly? do you have an email address where I can send you all the info?
you can send me an email on ruud[dot]de[dot]vries@xs4all[dot]nl.
But for the sake of others having the same problems it is maybe wise to discuss it here.
