VPN between Cisco and Mikrotik
Hello all,
I have 2 office which I want to join them with VPN.
In one I have a Cisco router with a static public IP and in the other office I have a dynamic public IP and I wan to put a Mikrotik device.
Is it possible to join both sites with VPN? The idea is to get 192.168.1.0/24 in one site and 192.168.2.0/24 in the other site.
In other Cisco VPN with static public IP I use configure this way:
interface Tunnel0
 ip unnumbered Dialer1
 tunnel source Dialer1
 tunnel mode ipsec ipv4
 tunnel destination x.x.x.x
 keepalive 60 5
 tunnel source Loopback0
 tunnel protection ipsec profile PERFIL_S2S
end
Now the problem is that I can not configure “tunnel destination x.x.x.x” in the CIsco site, this will dynamic IP.
I will appreciate your help.
Best regards.
Hello again,
I have this:
In Cisco with static IP:
interface Tunnel1
 description Mikrotik Tunnel
 ip address 10.0.0.1 255.255.255.0
 ip route 192.168.2.0 255.255.255.0 Tunnel1
In Mikrotik with dynamic IP:
interface gre add name=tunnel0 remote-address=45.x.x.x
ip address add address=10.0.0.2/24 interface=tunnel0
ip route add dst-address=192.168.1.0/24 gateway=10.0.0.2
Now I can make pings from Mikrotik to 10.0.0.1:
[admin@MikroTik] > ping 10.0.0.1
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0 10.0.0.1                                   56  44 109ms
    1 10.0.0.1                                   56  44 107ms
    2 10.0.0.1                                   56  44 106ms
    sent=3 received=3 packet-loss=0% min-rtt=106ms avg-rtt=107ms max-rtt=109ms
But not to the LAN side:
[admin@MikroTik] > ping 192.168.1.1
    0 192.168.1.1                                            timeout
    1 192.168.1.1                                            timeout
    2 192.168.1.1                                            timeout
    3 192.168.1.1                                            timeout
    sent=4 received=0 packet-loss=100%
From Cisco router I can do ping to remote 10.0.0.2 (I think it is not working, 6ms is not real for remote site):
#ping 10.0.0.2
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 10.0.0.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/6/8 ms
But nothing to remote LAN:
#ping 192.168.2.1
Sending 5, 100-byte ICMP Echos to 192.168.2.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Am I missing something?
I will appreciate any help.
Kind regards.
