I have a CCR1009 as a VPN gateway, both for distant ROS devices and for personal PCs. We do support sstp, ovpn, pptp and (rarely) ipsec. The WAN address was IPv4.
Now I try to use IPv6 as another (dual-stack) address on WAN port. ISP provided us with some IPv6 subnet, we’ve set it up, but sadly I can not use IPv6 as remote VPN point in any VPN connection on remote ROS devices (haven’t tried IPSec so far). Tesed sstp, ovpn, pptp - all says address is wrong.
I suspect Mirotik still won’t support VPN between IPv6 addresses, it that true? Any approach I can use to employ IPv6 now? The only thing I can imagine I can set up AAAA record in DNS pointing to router IPv6 address and use this name as VPN gatway name, but may this help at all?
