VPN between two routers
I have a question how? I have this problem:
How can i connect to client network with VPN? I try port forward, but is not correct solution.
You don’t need VPN to connect to the second router.
try to masquerade all your lan ip addresses.
did you have configured your routes correctly?
Just one route is needed to access your last router…
Set RoMON on all devices for example .
+1 for RoMON!
https://wiki.mikrotik.com/wiki/Manual:Tools/RoMON
Or simply:
/tool romon set enabled=yes secrets=qwe123
on both routers.
I dont need connect to router, i can do it. I need connect to last router LAN.
I need two VPN connections on one IP, but for two devices.
First vpn is working fine, it is my management vpn. But i need another connection directly to last routers lan.
You don’t need a second VPN for your last router.
Try to allow gre on 941 input chain too !
