VPN cannot ping some hosts
Hello, I have a strange problem with a vpn (both openvpn and pptp)
This is my setup
ROUTER: ETH6 = 192.168.100.254, ETH2 = EXTIP1
HOST 1: ETH0 = 192.168.100.30
HOST 2: ETH0 = EXTIP2, ETH1 = 192.168.100.31
EXTIP and EXTIP2 are two internet public addresses
The ethernets are all connected to the same switch
the hosts can communicate among them on any ip address, everything works ok on the local network.
When I connect through the vpn I can ping 192.168.100.30 but cannot ping 192.168.100.31
What can I do to find out what is wrong ?
This is an extract of my router config
set [ find default-name=ether3 ] master-port=ether2
set [ find default-name=ether4 ] master-port=ether2
set [ find default-name=ether5 ] master-port=ether2
set [ find default-name=ether7 ] master-port=ether6
set [ find default-name=ether8 ] master-port=ether6
set [ find default-name=ether9 ] master-port=ether6
set [ find default-name=ether10 ] master-port=ether6
/ppp profile
set 0 local-address=192.168.100.254 only-one=no remote-address=VPN-Pool \
    use-ipv6=no
add change-tcp-mss=yes local-address=10.0.0.102 name=openvpnwindows only-one=\
    no remote-address=10.0.0.101 use-ipv6=no
/interface ovpn-server server
set certificate=cert_3 cipher=blowfish128,aes128,aes192,aes256 default-profile=openvpn-win1 enabled=yes
/interface pptp-server server
set enabled=yes
add address=192.168.100.254/24 interface=ether6 network=192.168.100.0
add address=EXTIP1/27 interface=ether2 network=77.93.253.224
set allow-remote-requests=yes servers=8.8.8.8
/ip settings
set accept-redirects=yes
add action=reject chain=input dst-address=EXTIP1 dst-address-type="" \
    dst-port=23 fragment=no hotspot="" protocol=tcp reject-with=tcp-reset
    dst-port=21 fragment=no hotspot="" protocol=tcp reject-with=tcp-reset
/ppp secret
add name=vpn password=xxxxxxxxxxxxxx profile=openvpnwindows remote-ipv6-prefix=::/0 service=ovpn
/system clock
set time-zone-name=Europe/Rome
