Hello guys,
I want to connect to a vpn server through my mikrotik and some of the IPs on my LAN i want them to use the VPN client as gateway. i established the VPN connection in mikrotik, i can see the ip address under ip->addresses. I did a masquerade for a certain network (192.168.4.0/24) on the pptp gateway but no success. I can ping from the mikrotik the remote VPN address and i can traceroute from the VPN local address the 8.8.8.8 through the VPN server. But none of my desired devices can.
Is there a solution?
Cheers!
