VPN Client Cisco ---- > Mikrotik VPN
Any one, I need some info :
Can we make Mikrotik as a VPN server and we can connect to that server use VPN Client Software from CISCO ?
If Can, some body please post for step by step configuration in Mikrotik.
If can not, please advice what I should to do if we want access from outside and we Login as a internal client, so we can copy all data we need from server to Local.
thanks before.
MikroTik can act as an IPsec concentrator. So you should be able to create a VPN tunnel using any standard conform IPsec client.
I don’t know the Cisco client software, but have successfully created connections using different other hardware firewalls and software clients.
Best regards,
Christian Meis
Ow.. Thanks Christian.
But, I need some guide to create the configuration…can you post step by step for VPN tunneling in mikrotik or maybe you can give me the reference where I can get the guide for this issue ?
I really appreciate with your help and Info.
You should take a peek at the IPsec manual section (http://www.mikrotik.com/docs/ros/2.9/ip/ipsec). It’s fairly standard IPsec config and should not be that hard to get going (unless you never have configured IPsec anywhere)…
Best regards,
Christian Meis
