I’m using a Hex S with Router OS 6.47.9
My VPN client connection has been working fine until recently. I’ve noticed that the machine I want to use the VPN no longer goes through the VPN.
I have set up a VPN interface to direct this one machine on my lan to the VPN. In the interface menu it says the VPN is connected and running.
I see in the IP/Routes menu it says the the VPN is unreachable.
What might cause this?
My internet physical connection did change recently, it is still PPOE, only the physical cable from the street and IP address changed.
What configuration items should I look at that would cause the “unreachable” status in the IP/Routes menu?
