I have a very basic setup here. Just a WAN, LAN, bridge, and a PPTP server.
Local devices are accessing the WAN just fine.
I can connect to the VPN and login into the router, and surf out the WAN no problem.
But, I cannot ping devices on the LAN.
The intent is for my buddy to be able to login while he’s a t work and check his 3D printer, login to that, cancel print if need be, etc.
I have seen several posts regarding a similar problem, and I have tried several of the proposed fixes, but nothing has worked.
Here is an export for reference. I feel like I’m missing some small detail here.
Thank you all in advance!
BTW, I know I need to upgrade the firmware. That is happening soon.
# jul/19/2022 22:09:23 by RouterOS 6.45.7
# software id = DIED-0YD7
# model = CCR1009-7G-1C-1S+
# serial number = <CENSORED>
add name=bridge1
add name=WAN
add name=LAN
add name=dhcp ranges=192.168.1.100-192.168.1.254
add name="PPTP pool" next-pool=dhcp ranges=192.168.1.90-192.168.1.94
add address-pool=dhcp disabled=no interface=bridge1 name=dhcp1
/ppp profile
add bridge=bridge1 comment="This is where we define the parameters of the VPN co\
nnection. what IP we'll have, what limits we set, etc." local-address=\
"PPTP pool" name="Remote access" only-one=no remote-address=\
"PPTP pool" use-encryption=yes
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=sfp-sfpplus1
add bridge=bridge1 interface=combo1
/interface detect-internet
set detect-interface-list=all
add interface=ether1 list=WAN
/interface pptp-server server
set authentication=chap,mschap1,mschap2 default-profile="Remote access" \
enabled=yes
add address=192.168.1.1/24 comment=defconf interface=ether2 network=192.168.1.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.1.206 client-id=1:dc:a6:32:67:0:f9 comment=TRONXY \
mac-address=DC:A6:32:67:00:F9 server=dhcp1
add address=192.168.1.123 client-id=1:b8:27:eb:ec:75:ab comment=SIDEWINDER \
mac-address=B8:27:EB:EC:75:AB server=dhcp1
add address=192.168.1.0/24 gateway=192.168.1.1 netmask=24
add action=accept chain=input
dst-port=1723 log=yes protocol=tcp
out-interface-list=WAN
add disabled=yes distance=1 gateway=192.168.1.1
/ppp secret
add comment="This is the login and password used for PPTP VPN" name=<CENSORED>
/system clock
set time-zone-name=America/Chicago
/system identity
set name="Router"
