VPN Clients didn't get connected to the internet
Hello, i just Receiver my RB750g and i will use it only as a VPN Server so i could connect my iPhone or iPad from outside. Does anyone has a newbi Tutorial how to enable the VPN Server so that i could access? I could use ipsec or pptp or l2pt. The Router is behind an avm 7390vdsl Router which will do the Router thing.
Thanks for your help
http://wiki.mikrotik.com/wiki/Tunnels
hi there
you have to enable pptp server find it on interface tab
than you have to add a rule
/ppp secret
add name=“something” service=pptp password=“something” profile=default
local-address=170.14.1.1 remote-address=170.14.1.2
and pptp is configured
post comment after you try
hello guys,
thanks for your help everything works fine now. Only some problems with access via cellphone because of nat and non public ips from the cellphone provider.
I have to test some things if it works via another dsl account.
Hello i have now a New problem the Devices which are connected via VPN didn’t get into the Internet via my Router :frowning:
Annone an idea the ip’s are in the Same range
No one any idea?
i use a local net 192.168.20.xxx the range for the vpn is 192.168.20.200-250 the vpn server has 192.168.20.200 the dns server and gateway to the internet via avm 7390 is 192.168.20.1. I could connect to local ip adresses but not to the internet. do i have to make a tunnel 192.168.20.1 to 192.168.20.200 or what is the problem?
