VPN configuration public Ip to private Ip address
Can i ask how do i configure VPN access from static public ip to a static private address?
Would you tell me your question more clearly?
If I guessed right, you want your VPN client (like PPTP Clients) access to your LAN which connected to your Router Board.
For this go to / IP firewall nat and masquerade VPN Client Address Range. if nothing happend, there must be somthing wrong with routes.
Thanks for the reply but i was informed since i posted this topic that my current network (public to private ip’s 10.152.x.x to pppoe 10.100.x.x client ip) has double natting and vpn will only work in one direction, that is outbound but not inbound am i correct in this?
I still don’t understand your problem as clear as you know. So, Would you mind send me some info:
In terminal:
/ IP Firewall NAT print detail
/ IP route print detail
/ IP address print detail
/ Interface print detail
These info may help.
Thanks.
